Dishwasher motor roatation direction
Started by
Guest_WW2N_*
, May 22 2005 06:48 AM
1 reply to this topic
#1
Guest_WW2N_*
Posted 22 May 2005 - 06:48 AM
I have a Kenmore dishwasher that is designed to rotate the motor in one direction to wash and than the other direction to drain. The motor is rotation direction is random now. How is the direction controlled on the motor. It is a 4 wire motor. I assume it has a seperate set of windsing to start the motor in the proper direction. Does it have a capacitor to put the power at a different phase? The the power stay on the direction windings continuous or just when the motor starts? What is done to make it go forward and what is done to make it go in the reverse direction? I want to determine if the problem is with the motor or the control circuit.
#2
Posted 22 May 2005 - 07:40 AM
All Kenmore products, including dishwashers, are made by several different manufacturers, without a Model number to see who made it we can only guess, and that is not what you want us to do....usually the timer/control gives power to a start relay, whichever side gets the voltage, the relay starts the motor in that direction.....provide the Model number....Pegi
Buy your parts here!
Read More
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
