GE 30" CONVECTION WALL OVEN
6 replies to this topic
#1 peaches
peaches
  • 3 posts
Posted 22 May 2005 - 09:54 AM
Oh! PLEASE!!!!!! Help me wise Mr. Samurai Repair Man
help!:yikes:  I am trying to test out the pink eraser test on my F7 error code, but I can't tell by the tech drawings what the ribbon connector is.  I believe it is that clear 3" wide looking piece of plastic.
Also I am not sure how hard to pull on the connector so as to not break it.
Please help:shock:!  Two cases of beer for the Samurai Repair man
peaches
#2 kdog
    RoughShod
  • 7,428 posts
Posted 22 May 2005 - 12:01 PM
yes, the thin plastic track is the ribbon,usually there is a retainer at the end that connects to the board with small plastic pins that need to be depressed to allow disconnection-be very careful not to kink the plastic and do not use a metal tool directly on the plasic- what is the "pink eraser test"??
  • 24,232 posts
Posted 22 May 2005 - 04:21 PM
The thin mylar strip you describe is the descriptively-named ribbon connector. To disconnect it from the black receptacle, lift the posts on either end of the receptacle.
Kdog, the pink-pencil eraser test is described here.
#4 peaches
peaches
  • 3 posts
Posted 23 May 2005 - 02:53 PM
:party:I did it......I did it..........i did it.........
thanks to this wonderful website I saved myself $345.00 in parts and $160 in labor, by trying to do it myself first. But know my next thought is, how long will my repair last for????:?
Also wil attempting this repair when I was securing the ribbon connector back into the :(  Any thoughts?
  • 24,232 posts
Posted 24 May 2005 - 04:06 PM
Huh? :huh:
#6 peaches
peaches
  • 3 posts
Posted 24 May 2005 - 04:52 PM
:? I must have been interrupted while composing that last part of my message.  Let's try this again
while attempting this repair,  when I was securing the ribbon connector back into the connector one of the post extension that you squeeze to pull out the receptacle broke off.  :(  Any thoughts?
Also do you think that this repair will hold for a while?  Any posts out there to suggest that this might recurr again?
  • 24,232 posts
Posted 24 May 2005 - 05:04 PM
As long as the ribbon is seated all the way down and making contact, you'll be alright.
It's a GE-- you can count on it to break again!
