Grimmspropeller
Kenmore Front Load Washer Woes
132 posts in this topic
Banging sounds in the Kenmore Front Loading washers! (model 970.C40042.00)
I read some mailbag threads saying that there are two problems here:
1.) pulley is loose on the shaft
2.)bearing is bust and the whole back part of the tub needs replaced because the engineers at Frigitmore built it integrated into the plastic tub casing.
Unfortunately my problem is neither.  The bearing is fine.  No rust, no leaks.  The pulley fits perfectly and extremely tight on the drive shaft.  The problem is that the whole metal tub/shaft/pulley have play if you push and pull the pulley in and out.  It's as if the pulley is NOT pulling the tub tight up against the bearing.
I have tried tightening the bolt that holds the pulley in place hoping that that would pull it farther down on the shaft and get rid of this play, but alas it doesn't help.   Is it possible to put a washer on the shaft between the bearing and pulley hopefully eliminating the play?  Help me Obi Wan Kenobi's!  You're all, my only hope.  The metal tub is starting to cut into the interior plastic tub housing during spin cycle. YIKES! noisy!
Rust and leak streaks are signs of end-term bearing failure; the absense of these is not a conclusive indication that the bearing is unimpaired.
Remove the belt from the drum pulley and spin the drum by hand.  If you hear noise, that's the bearing.  There's a less expensive bearing kit available here
I just replaced the bearings on my Frigidaire front-loader rear tub assembly which is very similar to yours.  What a pain in the butt....  The inner stainless tub didn't want to come out of the rear tub half.  I had to use a wooden rod and a hammer to punch it out.  I then found that  the inner bearing was totally shot as it was covered in brown goop.  The dead bearing came out of the tub in pieces after repeated attempts w/ a metal pipe and hammer.
The cost of new bearings+bearing seal+tub seal w/ shipping came to about $45 after a lot of searching.  If I had to do it over again, I'd certainly consider buying a new rear tub assembly which comes the new bearings and the bearing seal already pressed.  I think it comes with a new tub seal too(but don't quote me on that).  Under $140 shipped!
now comes as an entire assembly-front and rear tub shells already assembled(bolted together with 17 bolts) and the spin basket inside and rear pulley installed- just swap it out,front boot,weights,motor and airdome are the only pieces to exchange. price is under $150.00 complete even up here in canada,sure to be less in the good ol' u.s. of a.
Come on Kdog, don't just tease us........
Tell us a part# and where???????
That sounds to good to be true, is that price of $150 customer retail price or wholesale price?
o.k. here it is  part #134453200 tub ass'y.  retails at sears here for 149.95(plus tip),designed so one person can replace it in the home(still time consuming).
Well, wouldn't you know it, Sears in USA website doesn't list that part#.
Cost $208 to $221 retail on multiple internet sites that I use for pricing.
My wholesale price from Marcone: $195.19
Budget Appliance Repair, would you please post the part number for this? I think it's the answer to my problem. My FL washer is a Kenmore 417.40042990 which started staining my clothes with oil and making lots of noise. The nice man from Sears came out and said it'd be $450 for parts and another  $450 for labor.  Needless to say, he wasn't surprised that we declined!He verified that the bearings were shot. Can I ass-u-me that this meant the "rear bearing" assembly discussed in this item? Is that the part that always goes on these machines?
Why not use this bearing kit?
S---s will nor replace just the bearings. Their argument (up until recently) would have been that it wasn't a "factory authorised repair". Given that Friggidaire now supply a bearing kit, I'd like to hear their argument now.
Also, you'll pay about double the retail price for a part used as part of a repair job. Labour on a tub replacement - say 3 hours at $60/hour, plus trip charge, around $250. Add extra if the dryer is stacked on top for a helper to de/re-stack.
I've been away from them for nearly three years, perhaps some of the current S---s/fellow "exes" could comment.
Double the price, I'd expect. But ten times? Outrageous. If you're right, and this can be done for $40, I will certainly be donating to the beer fund around here. (And imagining, but not going on, a serious whoopass rampage)I don't get it, though. So many people seem to have the same problem with this washer or ones like it and are so angry...if it can be a $40 repair, why isn't everybody shouting this from the rooftops?
Binki, The part# is in the post just above mine.
Here it is again: 134453200 and RepairClinc can get it for you
CLICK HERE to order
It doesn't show a picture but it is the complete assembled outer tub with inner stainless steel spin basket with all new parts for only $218.40 instead of $250.90 for just the back tub half with bearings and seals.
The problem with just ordering the bearings is once you get it apart you might find that the tub shaft may be rusted badly from leaking for a long time and also who knows how bad the tub spider is at this point, seems to be quite a few of this breaking also.
The complete tub assembly would most diffinitely the easiest way for a novice and then you would have an almost new machine.
Oh, I get it. I misinterpreted your post about Sears in USA not carrying that part. Thanks for setting me straight.Well, I'm feeling pretty confident after having fixed the dishwasher last night, and my birthday's coming up and all...I'm going for it. Osu, sensei, and don't be surprised to see me back here asking lots of questions...
Question: my frigidaire (kenmore) front load washer has become really, really loud in the high speed spin.  Is this the same problem being discussed here?  It sounds like a jet getting ready to take off!
I can't detect any wobble or leaking oil, but I assume this is the bearing getting ready to go out.  It has been stable (not getting worse) for several months or more.  Wife is threatening to make a call, so need to move fast to save some cash.
Thanks for any help with this.  I can't believe I found this discussion group, you all are amazing!
John
It's not a banging or squealing sound, really just a very loud whooshing sound.  Not high pitched at all.  Maybe a bit like surf crashing on a beach?  But very loud!
You need to take a look at the area around the pulley at the back - any signs of brown gunge oozing out?
I can almost garantee you that the noise is the bearing going out. Do as MadMac says, remove the back panel and look for brown streaking down back of tub.
Even if no streaking yet still believe you are hearing the first signs of the bearing going out, (meaning seal is leaking).
OK, I have a visual on brown gunge.  Will be replacing entire tub unit with part from repairclinic.
Thanks for the pearls of wisdom, Oh wise ones!
I bought a Staber to replace the Frigidaire POS that I spent hours taking apart. The replacemeent parts mentioned in this thread weren't known to me 8 months ago when I replaced the Frigidaire. All I can say is that I am very happy with the Staber. If you want to get more info, you will find it here, or you can email me at robert.perkins@hotpop.com. I have no affiliation with Staber; I just hate Frigidaire now.
I am committed to the Frigidaire because I did a custom under-counter installation.  So I need a front-loader with all controls on the front.  Not many to chose from with those specs.
Otherwise I would definitely be looking around for a different machine.
John
Please, post how the installation goes. I'm having trouble convincing my spouse that we can/should do this repair ourselves.
Placed my order at repairclinic.com The whole assembly is special order, so I will report back when I receive the part. I expect it will be a few weeks.
Hopefully I can tackle this. I found the instructions at this link.
I can do most home repairs, this should be do-able I think.
Wow jms336, that was a great read. I did the disassembly of my own Frigidaire (FWT647GHS - Canadian model) last night and found it easier to remove the drum by first laying the machine on its (open) back and lifting the frame up and over it. Took 90 minutes to take apart.
Do you know how to get the tub bearing out of the back outer tub half? It seems pressed in, and looks like a press would be required to get it out again.
DHL dropped my new complete assembly off Saturday (Wow - only $13 for overnight shipping on that beast !)  and I tackled the repair yesterday.  The assy was on back order at repairclinic when I ordered it a few weeks ago.  I have not done a lot of appliance repair in the past but am fairly mechanically minded and don't mind figuring stuff out as I go.
Bottom line - it is not a difficult thing to swap the unit out.  The instructions at the link I posted above are useful, but I really didn't need them that much.  If you have some basic tools and common sense, you can do this repair.  A couple extra hands are useful when you go to place the drum assembly back into the machine, as the front weight will be on it and that makes it pretty heavy.  Other than that, it is just a matter of looking at the machine with a little common sense, removing everything connected to the drum assy, transferring it back onto the new unit, maneuvering it into place, and hooking up your hoses and wires.
When time permits I will be replacing the bearing in my old unit and will either keep that around for a spare or might sell it to help with my costs.  Also, some $$ is going into the samurai beer fund for all the help I have gotten here.
John
Guest
This topic is now closed to further replies.
