Thermador CT227NS Double Convection Oven from 1998
1 reply to this topic
#1 czucz
czucz
  • 1 posts
Posted 23 May 2005 - 03:48 AM
Hi all,
Any help would be welcome.
I removed a Thermador double wall oven and put it in a new location.
I took the exact subpanel and breakers and reinstalled them as per the wiring diagram.
I thought everything was great once I turned all the breakers on as the lights, the clock and all of the indicators are working just fine.
However, no heat.
I have tried both the upper and lower ovens on broil, convection and bake but nothing.
I'm a real novice at this and am hoping for some direction before I have to call in a repair guy.
Thanks in advance,
Eugene
  • 24,360 posts
Posted 23 May 2005 - 04:12 AM
May not be a problem with the wiring, but with the oven.  You can verify the supply voltage to the oven with your meter.  If it checks out, you know the oven itself has a problem.  Then the fun begins!
