Dead pump?
4 replies to this topic
#1 Ander038
Ander038
  • 2 posts
Posted 23 May 2005 - 08:53 AM
*Bows and Salutes center of the appliance Dojo*...
It seems wise one...that my front loading Frigidaire washer (model FWR645RHS1) has given up the ghost...pump was making terrible noises for a bout a week..and now...will not empty the tub...
As I am a car guru..and not worthy to carry the Master's wrench in appliance land....I would ask for help in assesment of my diagnosis, and in how to proceed for repair...
I have taken the front and rear off of this, and can handle tools without TOO much injury to myself...so I would prefer to repair this myself, provided it's in my skill level.
Wisdom would be much appreciated....
#2 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 23 May 2005 - 09:58 AM
open up the rubber grommet to the pump and remove the coins(probably a quarter) they tend to lay there vibrating for a while,and then take a notion to flip up and block the inlet to the pump and cut off water flow.          :D
    Shōgun
  • Master Samurai Tech
  • 30,720 posts
Posted 23 May 2005 - 03:05 PM
That's a good thing to check but, be advised:  I've seen several of these pump fail, making the same brinnelling noise, without having any obstructions in the impeller.
#4 Ander038
Ander038
  • 2 posts
Posted 23 May 2005 - 03:58 PM
OK.....pump is clear....but...now....motor seems to run...but impeller is not moving water...
So...what part is it that I replace?
and MANY thanks for the advice
    Shōgun
  • 30,720 posts
Posted 23 May 2005 - 04:53 PM
Ensure the pump suction hose is clear thusly:
  • Add a litte water to the drum, a quart will do nicely, thank you.
  • remove the suction hose (the accordion one) from the pump.
  • If water doesn't come gushing out, remove the panties stuck inside the suction hose.
Once this is completed and the pump still won't move water, replace the pump.
