Waste King electric range element won't turn off
3 replies to this topic
#1 mauigetaway
mauigetaway
  • 2 posts
Posted 23 May 2005 - 10:01 AM
Waste King electric element not turning off.  Knob is working but it won't turn off. Right now, I turned off the circuit breaker but  life has to go back to normal.  This is an older unit around 1970's and is built in so I can't lift up the top.  Is there anyway to disconnect just that burner?
If not, how about a good,reasonable repairman in Glendale,CA.
Mahalo.
#2 Pegi
Pegi
  • 13,120 posts
Posted 23 May 2005 - 11:40 AM
I assume you are talking about one of the burners on the top.   Do the burners just unplug from the block?  If this is what you are referring to the inf. switch to the element is shorted or something in the range is grounded giving power to this burner at all times.  Guess you could try cuttng the voltage to the range and accessing the switch for this burner and un-plugging the wires and tapeing them off so the burner will not get any voltage if you cannot just un-plug said burner from the burner block, or removing the wires to the burner and tapeing them off.  We cannot tell what your range looks like and what sort of burners it has with the information provided
#3 mauigetaway
mauigetaway
  • 2 posts
Posted 25 May 2005 - 12:21 PM
So if I tape off the wires , it won't be using any electricity?  Would it also work if I unplugged the burner?  Thanks so much for your information.
#4 Pegi
Pegi
  • 13,120 posts
Posted 25 May 2005 - 12:39 PM
I would imagine the burner would not get hot if it was not plugged into the range....however the block it plugs into would still have electricity where said burner was plugged into so any liquid that might be spilled could get into this and cause the whole range to short out.  Would be better to cut or unplug the wires to the burner block and tape them off, or better still cut or remove the wires to the switch and tape them off..
