  • Announcements
Guest NiceMoveDad
Admiral Hvy Duty Giant Capacity Dryer..Loose wires
10 posts in this topic
Moving a Admiral Model LNC8757A77 dryer and I slipped down the stairs.  My helper was left holding the top of the dryer which had seperated enough that the four wires that attach to the back left came loose from their clips.  Manual lost years ago.  I did some research online and facing the dryer from the front the Yellow dot marked item is I believe the High Limit Thermostat which still had a Blue Wire clipped to it.  Next to it is the Pink dot Thermal Fuse?  Now I have a Tan/Beige wire which I think connects opposite the still attached Blue (judging by fact other two wires seem too short to reach)?  Now I have a Black wire marked F2 and a Grey wire marked F1.  From Left to Right facing the dryer where does Black and Grey go on the pink dotted thermal fuse?  I am so afraid to shock or blow up somone with this Gas Dryer and we are so behind on bills due to unexpected car repair I cannot really afford to call in a professional for a simple clip reattachment.  Any help for low paid Soldier and Father of Four? Thanks in advance for any help.
Post that wiring diagram here and we'll get you fixed up before you can say, "Osama Bin Fartin'."
How  I post it? I have it scanned into a pdf file, but am unable to determine how to copy the picture of the scan or attach the pdf file to this message.  Sorry I just cannot seem to figure that out.  I could email it in or you could give me directions, but I am almost as bad with computers as appliances it seems.  Sorry to be such a botehr, but I did try all I can think of and th eoptions do not seem to work as a copy and paste.
I see you're still Loitering in the Threshold.  You have to register to be able to upload attachments.
And, yes, it's free.
Finnaly came back from Maneuvers and able to scan, but due to file size limit had to do in three parts.  Hope you can help me now?! ;-)
PART 1
Scan001.PDF
Part 3 and any advis eor help or even reading and saying "Your screwed buddy!" is appreciated.  Last resort I call for help, but I'd like to fix it myself and feel i unmessed up the whole thing ;-)
Scan003.PDF
Either wire to either terminal, makes no difference. You may also have broken the ignitor depending on how violent a drop it took.
So as long a sF! and F2 are attached to the Thermal Fuse (Pink Dot Item) I should be okay?   Thanks.  Not to bad a drop more like as lide lol.
Yep, one on F1, one on F2.
