  • Announcements
Loganhbrown
Asko 10505 washing machine draining problems
1 post in this topic
Asko washer will only drain when I hold the hose close to the ground. I looked in the needle trap and it was clean as a whistle. I checked the hose for blockage and found none. I suspected my crappy detergent and switched to low sudsing-no dice. Made sure hose outlet height was within specified height limit-yup. It goes thru whole wash cycle and before the drain and spin cycle is swashes the clothes around in the water and then whirs the pump a couple times and stops. BUT, when I hold the hose in a bucket on floor, it purrs like a kitten.
What up?
