Guest Beano357
GE IM6 Icemaker
10 posts in this topic
I have a GE fridge with the IM6 icemaker, it despenses water  but will not give either crushed or cubed ice when the lever is pushed. From what I can tell it is not in fault mode the light stays solid.
It continues to make ice and over fill the tray leaving many cubes throught out the freezer.
Any Ideas?
Basic primer on the GE IM6 here.
Basic primer? I am unable to find any info on this. What is it?
See the word "here" in blue? Click it and your will see all....
If it will make but not dispense ice is the auger motor running??  If so you have something broken in the ice bin probably.  If it does not run the auger motor could be out or getting no voltage from the disp board.  If the paddle does not turn the ice maker off and is allowing the bucket to over fill there is replacement paddle with a beveled down edge to address this overfill problem.  And the "model "   number of the frig would let us see what sort of set up is in this box?????
Model: GSL25JFPA BS
Serial: LF213366
When the lever is pushed, I can hear a soft click toward the back right of the machine.
The motor does not start? I plan on taking the thing apart this weekend, wish me luck.
Luck!
:help:
I posted this on another forum that has not been looked at so I'm trying here. Where can I find the complete recall for the GE GSH25JFRE-CC? I may have a problem that it covers. I have an IM6 I/M that will not dispense ice. When the dispense lever is pushed, the convenience light dims and nothing happens. However, if I disconnect the solenoid for the ice chute door and open the door manually, the ice dispenses normally. Is that a PCB fault or the Solenoid?:headbang:
Just an update FYI, I had GE Service come out and the tech told me that this is a very common problem and he replaced the motherboard @ no charge in about 15 minutes. When I called GE they denied any problems and told me I would have to pay for the service call.
Director
They are trained to "have no clue"...cannot let the public know their GE or whatever brand appliance might have a problem..:?
Guest
This topic is now closed to further replies.
