  • Announcements
miked
Kenmore dishwasher leaking (PICTURES)
6 posts in this topic
Kenmore dishwasher 363.14458692
There is water coming from under unit and I am unable to determine where the source is.  Also not sure how much I need to take apart to figure out where the problem is coming from.
See photo below:
I suspect the water is coming from the white plastic unit in the center of the picture.  Specifically around the white crusty stuff (calcium?).  The water seems to be most apparent around where this white material is.  I have more pictures at http://daviscg.com/user440/dishwasher/index.html.
Any assistance would be appreciated.  Thanks!
Mike
Couldn't determine from your pictures exactly where the water is leaking but see signs of the calcium from leak around the upper clamp that holds the motor to the pump outlet and also a little sign around the drain and upper wash arm hoses.
Tighten that clamp at the top of the motor/pump and check to make sure both small hoses are tight.
Most likely cause of the leak is a bad pump seal or the small seal for the drain flapper valve has gone bad.
Dry the motor/pump real good then run it and see if you feel water around where the black motor attaches to the white pump body. If the water is coming down from where the motor connects to the pump then most diffinitely a bad pump impeller and seal kit.
The water seems to be collecting from the area circled in the picture below:
If this is leaking down from a bad pump seal, what needs to be removed to inspect?
Thanks!
Mike
You need a new motor/pump assembly.
Sounds good.  Think I can get away with the pump only?  How do you remove it?
That'd grat if you could buy just the pump, but I think you need to buy the whole pump/motor assembly-- GE makes more money that way (GE made this dishwasher).
