Neptune commits HariKari after final rinse.
23 replies to this topic
#21 cgaudio
cgaudio
  • 16 posts
Posted 13 June 2005 - 01:57 AM
I must inform honorable teacher that all the water in the river will not remove fish blood. A long Oxy-Clean soak is required most of the time.
New problem. No spin! It dies after 3rd rinse. Checked balance circuit and it is closed (OK). Locked door light coming on, so wax and switches ok, (well, maybe not spin enable). I find now that if the washer is set on Wash and Wear and cold/cold, it works great. Some settings, like cotton/sturdy, no spin.
Just happy it works at all, so will look into this further and get back to you.
Thanks!
-Chuck
#22 cgaudio
cgaudio
  • 16 posts
Posted 30 June 2005 - 04:00 AM
OK, Fellas, new problem:
Now this pig won't fill! I looked all the way out to page 18 for a similar problem, but couldn't find one.
Thanks!
-Chuck
#23 cgaudio
cgaudio
  • 16 posts
Posted 01 July 2005 - 01:51 AM
Thanks!
-Chuck
More:
Wife in hospital, so trying to get this done in the few hours a day I'm home to sleep.
I checked continuity from 12T to the pressure switch1, to pressure switch 12, and the P1-1, and from 11 to 12 on the pressure switch. All OK.
I had just used the washer, so the water lines are not kinked.
I do not get 120 across the water valves. The troubleshooting sheet sez replace control board. There is nothing on it obviously burnt. What should I look for/test to fix the board?
Thanks!
-Chuck
#24 cgaudio
cgaudio
  • 16 posts
Posted 22 July 2005 - 07:51 AM
This is the final posting, I hope. I got a control board with the souped up triacs, etc., put it in. All problems solved, machine working like new.
THANKS AGAIN TO ALL!
-Chuck
