washer wont spin after wash.
8 replies to this topic
#1 Lurker_Tillerman 33_*
  • Lurking at the Threshold
Posted 24 May 2005 - 01:33 PM
Hi all,
Need help, I own this above washer.  Had it for several months now.  The problem is after it washes and goes to spin and drain it wont spin.  I have to open the lid and then close it to get it to spin.  No matter what size load.  It also only does this some of the time... Help Wife Getting Pissed at it.
Tillerman33
#2 Pegi
Pegi
  • 13,120 posts
Posted 24 May 2005 - 01:50 PM
The timer has a built in pause after the drain to let the transmission go into spin.  See if the washer is pausing for about 2-3 seconds.  If it is not the timer could be going bad.  If it does not drain or spin till you open and close the lid I would suspect you have a lid switch going bad.
#3 Lurker_tillerman33_*
Posted 24 May 2005 - 02:00 PM
The timer is ok.  it does pause for 2 to 3 seconds.  The lid switch is ok i think because the motor will turn on but it will not spin.  When you open then shut the lid the motor will engage the basket and then it will spin fine.  Its like the gear is not catching and the small pause of opening the lid will let the the drive engage
#4 Pegi
Pegi
  • 13,120 posts
Posted 24 May 2005 - 05:56 PM
yes, the pause in the timer does this for you, not sure why you have to open and close the lid since the timer does pause unless this is jarring something letting it move or come into contact.  will have to think about this some more...
#5 Lurker_illerman_*
Lurker_illerman_*
Posted 24 May 2005 - 08:06 PM
Ok I think I am explaining this wrong.  Everything works that is suppose to.  But the basket will not spin some times.  the motor will run , the timer works.  When you open the lid to look and see if the basket is spinning and it is not ,then i close the lid hear a "clunk" and the basket will start to spin.
hope that helps sensi
tillerman33
#6 Lurker_itllerman33_*
Posted 24 May 2005 - 08:08 PM
oh and it does drain
tillerman33
#7 nickfixit
nickfixit
  • 2,195 posts
  • Flavorite Brew:Glen Livit
Posted 25 May 2005 - 01:24 AM
I have been down this road many times. Your lid switch works, your timer works, and you have intermittent no spin condition.
Your gearcase is failing to make the shift from neutral to spin(intermittently). This is an internal gearcase problem.You need to replace the gearcase. If it's still under 1 year old the parts and labor are under warrenty. If it's 2-5 years old, the part is under warrenty, but you will pay for labor.
Nick
#8 Lurker_tiller man 3 3_*
Posted 29 May 2005 - 09:40 PM
what does that cost?
    Shōgun
  • Master Samurai Tech
  • 30,207 posts
Posted 31 May 2005 - 05:44 AM
Scroll down a bit and plug your appliance info into the Easy Appliance Parts Lookup Form and you'll find out exactly what the transmission costs.
