Kenmore 90 Series Washer 110-92491210
6 replies to this topic
#1 Hankb
Hankb
  • 4 posts
Posted 17 June 2006 - 10:01 AM
Hello All
   The washer is currently fully functional but It's just a matter of time before "what-ever it is" breaks. I'm trying to determine the "what-ever it is" portion. :)
There's a loud noise (squealing) that occurs when the washer begins to agitate. The noise continues through out the agitating cycle and during the spinning cycle.
Can you help me diagnose this problem? The noise is getting louder.
It's a Kenmore Direct-Drive model
THank You
Hank
The Grasshopper
#2 kdog
    RoughShod
  • 7,428 posts
Posted 17 June 2006 - 10:29 AM
could be a number of things-try and narrow down the area from which the noise is evident(eg. drain pump)
#3 Hankb
Hankb
  • 4 posts
Posted 17 June 2006 - 11:03 AM
Hello again.
When the washer is filling up there's no noise but once it's completly filled up with water and right when it begins to agitate is when the noise starts.
While the water drains there's no noise, but once it begins to spin the noise is present again.
I'm asuming it's not the pump. But what else can it be? Drive Coupler? Motor?
I don't think the dog-ears would have anything to do with it... would it?
Hank
#4 Hankb
Hankb
  • 4 posts
Posted 17 June 2006 - 11:53 AM
Just moved the washer and noticed rubber shavings on the washers location.
I think it's time to replace the motor coupler. Is there anything else I should check?
Once I receive my part, is there anything else I should verify? Free moving  tranny ? Etc?
THanks
Hank
#5 kdog
    RoughShod
  • 7,428 posts
Posted 17 June 2006 - 02:19 PM
just replace the coupling, part #285753 and go from there-no sense looking for trouble
#6 Hankb
Hankb
  • 4 posts
Posted 17 June 2006 - 06:00 PM
Just replaced the coupler. Unfortunatly the sound is still present. :yikes: This time it's more prevelant during the spin cycle.
The bearings looked fine on the motor and there was no play on the shafts.
Hmmmm :(
  • 24,321 posts
Posted 18 June 2006 - 05:36 AM
Run the washer with the cabinet removed and the lid switch jumpered out, try to locate the source of noise using your earballs.
And, just for grins, check that drive block:
