Kenmore 106.626636 ice maker troubles
5 replies to this topic
#1 humble_one
humble_one
  • 3 posts
Posted 25 May 2005 - 11:52 AM
The ice maker in my Kenmore model 106.626636 quit producing ice the other day.  After reading previous on this subject here is what I found.  Ice trays did not fill with water.  However, when I jumped the V and L the ice tray filled fine.  It only fills when I jump V and L.  Should I replace the ice maker control module or is it something else..  Your site is a wealth of information.  Keep up the nice work.
  • 24,360 posts
Posted 25 May 2005 - 01:12 PM
Did you try jumpering T to H to see if the icemaker would initiate the harvest cycle?  If it won't come git you a new icemaker:
http://fixitnow.com/...-day-buying.htm
#3 humble_one
humble_one
  • 3 posts
Posted 25 May 2005 - 04:35 PM
I did jump  T and H and it does compelete a harvest cycle. Now what can I try?
#4 Pegi
Pegi
  • 13,120 posts
Posted 25 May 2005 - 06:19 PM
When you jumped T to H did it fill with water before it went into the stall position to freeze the water for the next harvest cycle, or did it complete the cycle with no water entering.
#5 humble_one
humble_one
  • 3 posts
Posted 26 May 2005 - 11:43 AM
When I jumped T & H it complete a whole cycle.  No water dispensed. Then I jump T & H again.  This time as it was going through its cycle I jumped V & L.  After it completed its cycle water then fill the tray.
#6 Pegi
Pegi
  • 13,120 posts
Posted 27 May 2005 - 10:43 AM
If you jump T and H, the ice maker goes thru the cycle and no water enters, and you know the water valve is good, sounds like your ice maker is not giving power to the valve during the harvest cycle and the ice maker head is defective.  If the ice mold is yucky I would replace the whole ice maker.
