Tappan Gas Range Won't Light
#1
Posted 25 May 2005 - 02:51 PM
Wayne
#2
Posted 25 May 2005 - 05:42 PM
Wayne
#3
Posted 25 May 2005 - 06:13 PM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#4
Posted 26 May 2005 - 04:08 AM
Wayne
P.S. What is the pt # for the igniter and what would my cost be?
#5
Posted 26 May 2005 - 05:16 AM
#6
Posted 26 May 2005 - 05:32 AM
Wayne
#7
Posted 09 June 2005 - 06:06 AM
#8
Posted 09 June 2005 - 06:23 AM
1. Unplug AC power to oven
2. Unplug both wires going to gas valve
3. Check continuity between the two connections on the valve..should have continuity.
If not most likely a bad valve.
4. If continuity OK on valve, put connectors back on valve.
5. Plug AC power back in.
6. Turn oven on and check amp draw on line from ignitor to valve. If out of spec with
your style of ignitor, highly suspect ignitor even if ignitor is glowing.
In my case, it was the ignitor.
Wayne
#9
Posted 09 June 2005 - 06:32 AM
#10
Posted 09 June 2005 - 08:27 AM
#11
Guest_Shermo_*
Posted 11 December 2005 - 06:42 AM
My problem is that the oven sometimes will not light, or it may take a very long time to light, even though the igniter glows when it is turned on. When the oven does light, the temperature usually fluctuates, and rarely reaches the desired temperature. Oddly, when the range burners are lit, the oven temperature (once lit) remains relatively close to the desired temperature, but usually 25-50 degrees lower.
My question is, to replace the igniter, must you pull out oven, lay it on it's back & disconnect AC prior to safely replacing igniter? I don't think I can fit into the broiler section to replace igniter in its current location!
#12
Posted 11 December 2005 - 08:18 AM
I removed the broiler by just sliding it out and lifting to remove. Once this was done, I had enough room to replace the ignitor without completely removing the oven from the wall.
Wayne
#13
Posted 13 December 2005 - 12:25 PM
"May the hinges of our friendship never grow rusty"
-old Irish saying
Buy me a Beer: http://web.me.com/ze...man18007260692/
#14
Posted 10 June 2006 - 03:47 PM
mensch
