GE Built in Oven Err Code
12 replies to this topic
#1 tavalley
tavalley
  • 5 posts
Posted 26 June 2006 - 12:38 PM
HELP!  I have a GE Built in oven Model Number JTP18B0A2BB, the keypad works sometimes and not others.  It started when it would pop up Broil HI push start by it's self, I killed power and now if I hit "Bake" and the temp then hit start it displays "Err".  Does anyone have an idea?  I can only find this model number when I drop the "0" to  be a JTP18BA2BB.
tavalley
    Shōgun
  • Master Samurai Tech
  • 30,624 posts
Posted 26 June 2006 - 12:48 PM
Sounds like you've worn through the membrane on the touchpad and you need to replace it. You can buy the new touchpad here: http://www.repaircli....asp?R=154&P=69
#3 tavalley
tavalley
  • 5 posts
Posted 27 June 2006 - 01:20 AM
I can still use the Broil, one service guy told me it sounded like the clock control.  Does it still sound like the keypad to you?  Numbers do work but sometimes if you hit a 3 you get a 1.  We hardly use the oven, I can't believe it's worn out, but it is 6 years old.
THANKS,
tavalley
#4 Jedi Appliance Guy
Jedi Appliance Guy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 706 posts
Posted 27 June 2006 - 02:07 AM
It you hit bake does it not want you to enter a bake temperature?  The Force is with the Samurai.  He speaks the truth,
#5 tavalley
tavalley
  • 5 posts
Posted 27 June 2006 - 02:35 AM
Yes, If I hit Bake it does want me to enter a temp, I have to hit the numbers slow and hard to get the correct temp, then when I hit the Start button the temp disapears and the letters "Err" appear.
tavalley
#6 Jedi Appliance Guy
Jedi Appliance Guy
    Senpai
  • PipPipPipPip
  • 706 posts
Posted 27 June 2006 - 02:56 AM
The Force is telling me your oven may have been put into centigrade mode.  Try entering 100 degrees. (212 centigrade) and see if it accepts that.
#7 tavalley
tavalley
  • 5 posts
Posted 27 June 2006 - 03:18 AM
You are correct, it wouldn't let me put in 100 but accepted 105 and it turned on, how do I get back to "F".  I still think I may have a keypad problem, it's hard to enter numbers and sometimes puts numbers that I haven't pressed.
Thanks!!!!!!!!!
tavalley
    Shōgun
  • 30,624 posts
Posted 27 June 2006 - 03:22 AM
Your owner's manual explains how to switch from C to F.
#9 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 27 June 2006 - 06:36 AM
[align=left]Fahrenheit or Celsius Temperature Selection[/align]
[align=left]Your oven control is set to use the Fahrenheit[/align]
[align=left]temperature selections but you may change this[/align]
[align=left]to use the Celsius selections.[/align]
[align=left]Press the
BAKE and BROIL HI/LO[/align]
[align=left]pads (on double oven models use[/align]
[align=left]the
upper oven controls) at the same[/align]
[align=left]time for 3 seconds until the display[/align]
[align=left]shows
SF.[/align]
BROIL HI/LO pad. The[/align]
[align=left]display will show
F (Fahrenheit).[/align]
BROIL HI/LO pad again. The[/align]
C (Celsius).[/align]
START pad.[/align]
[align=left]NOTE:
On double oven models the new setting[/align]
[align=left]will be displayed for both ovens.[/align]
    Shōgun
  • 30,624 posts
Posted 27 June 2006 - 06:49 AM
And Pegi expertly delivers the coup de grâce. :dude:
#11 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 27 June 2006 - 07:09 AM
Thanks, however believe he still has a problem with his key pad??
#12 tavalley
tavalley
  • 5 posts
Posted 27 June 2006 - 07:10 AM
Thanks to all !!!
#13 arflimey
arflimey
  • 2 posts
Posted 23 August 2006 - 07:13 AM
I have had numerous problems with the clock/oven control terminal, the ribbon connector is faulty at times, disconnecting and reconnecting helps for a period of time.
Now the oven broil and oven light and buzzer activate by themselves because of a faulty relay, checked relays found heat residue on the contacts - need help locating relays if they are even available, also can this board be repaired. Robertshaw is the company that makes these circuit boards.
Any information is appreciated.
