JohnnieBgood
Kenmore Elite MOD 110 20992991-will fill and won't advance
6 posts in this topic
My washer will fill with water, but will not advance to the next cycle.
I tried on/off several times and rotating the knob to several places, especially rinse, but it only hums.
I've read several points of interest on this formum and I think I'm down to:
Lid Switch(x?)
Bad Pressure Switch
Bad Coupler
Bad Motor
Bad Timer
Is there any tips for me to really narrow it down?
JohnnieBgood
Let us look at some details.  After it stops filling is the washer dead? or do you hear the motor humming down at the bottom of the washer??   If it is dead we could have a bad fill level switch, bad lid switch, bad wiring harness, bad motor.  If you hear the motor humming you could have a broken coupler which would not let it agitate or spin, BUT it would drain.  You could have something in your pump jamming the motor.  You could have a locked up tranny jamming the motor.  There are other things that it could be but let us start here first.  Pegi
Thanks Pegi.
The hum is coming from the bottom of the washer for sure.
I'm about to drain it with a sump, slide it out and see if I can see anything in the pump.
brb,
jbg
Trouble shooting in progress.
Maybe I can rule out the lid switch?(with the lid closed, I turned the know to spin, it hums. When I open the lid the humming stops)
I'm draining the Tub with a small sump now, so that I can pull it out and examin the electrical components and tranny.
jbg
Eureka!!!
I emptied the tub, rolled the washer on its side and removed the cardborad base so I could view the motor, pump, etc.
I removed the large inlet hose from the tub and found the tail end of piece of cloth. Manually spinning the drive coupler with my thumb and pulling the cloth at the same time yielded the root cause to my problem. The cloth had the pump under wraps ó¿ó
Hooked everything up for a test run, Everything works fine.
Thanks you so much! I owe you one.
Kind Regards
johnnieBgood
