Maytag Neptune #MAH3000AWW
7 replies to this topic
#1 eZAK
eZAK
  • 18 posts
  • Flavorite Brew:Home Brew!
Posted 28 June 2006 - 07:10 AM
I having some more problems with my Neptune mod (P) #MAH3000AWW.
Last year I replaced the board and the wax motor. (I missed the deadline on the lawsuit by a few months):X
Now it is leaking and very loud during spin. Inner SS drum seams loose.
I'm thinking bearings and seals?
Any suggestions, tips, or tricks I should be aware of? Anything else I should replace while I'm in there?
Thank You!
Pat Zak
#2 SuperTec
SuperTec
    Ikkō-ikki
  • Appliantologist
  • 59 posts
Posted 28 June 2006 - 12:58 PM
You would be thinking correctly... The bearing is part of the tub assembly. Gets a little costly, but if you like the front loader, it is worth it...
Prices subject to change upon customers annoyance....
#3 Trying to help
Trying to help
  • 2,464 posts
Posted 28 June 2006 - 01:43 PM
The inner tub is held in place by 3 bolts located behind the baffles that attach to the rear of your inner drum. If one has snapped, it will make the inner drum loose and create a loud banging in spin. The baffles are held in place by two screws on each baffle. Might want to check the condition of those bolts as well.
#4 chrisboc
chrisboc
  • 19 posts
Posted 28 June 2006 - 03:16 PM
eZAK,
I have a brand new in the box outer drum that I would gladly part with for a lot less than a new one.
I just replaced mine. It's a pretty easy job. The complete instructions along with a new lip seal kit are in the box. Takes a couple of hours for the job.
See the picture below. It is brand new in the box unopened. They cost about $240 shipped. I would part with this one for only $175 shipped to your door.
If anyone else reads this and wants it, just send me an email.
Regards
#5 eZAK
eZAK
  • 18 posts
Posted 29 June 2006 - 03:19 AM
Thanks fellas for the replies so far.
Chrisboc,
I'm interested in your offer for the outer drum kit. I have sent you a P.M. I would have sent you an email but you don't have one listed! I can be reached at eZAK61@sbcglobal.net
Trying to help,        All three bolts appear to be intact. Thanks
Now my other concern is the issue with the mold on the drum boot seal. Is there a fix or a new and improved part for this? Please provide part numbers.
Here are the parts I think I need an plan to order; (Please correct if items are wrong or not needed)
22004465 - Outer drum assembly (chrisboc)
22004081 - Spinner shaft
12001788 - Belt kit
12002022 - Lip seal kit ??
??????      - Boot seal
This will be my first major tear down of a washer so please let me know if I need anything else or I'm forgeting something.
Thanks Again
Pat Zak
#6 chrisboc
chrisboc
  • 19 posts
Posted 29 June 2006 - 04:40 AM
eZAK,
I sent you an email with my phone number. Give me a call if you like.
As far as the parts needed, the lip seal kit is included in the outer drum package. I would get a new belt. I didn't change the spinner or the boot. Mine looked good.
This isn't that hard of a job. Just be patient and pay attention to what you are doing. If you get in a bind just ask for help and the people on here will jump at the chance to help you. They helped me a lot.
Talk to you soon.
#7 eZAK
eZAK
  • 18 posts
Posted 29 June 2006 - 10:24 AM
I did not receive any email 'chrisboc'!
#8 chrisboc
chrisboc
  • 19 posts
Posted 29 June 2006 - 11:17 AM
Sorry, it was still in my outbox in Outlook. Just pushed send. You should have it now.
