The days of Monkey Boy Service Calls are over...
Click here to check out our fun short course and learn how to get the most out of Appliantology.
Guest Neptune\s Suck
Neptune Loud when spinning - Not good for babby
4 posts in this topic
Help.. What is the cause?
Noise only happens durring spin cycle and is extremely loud
Sounds like another case of bad drum bearings.
Good grief, that is a newer model than mine too.  Thats gonna take a new outer tub assembly if its the bearings. Some techs will have the know how to replace just bearings but it takes special tools and special bearings the Maytag does not advertise as an alternative replacement. Outer tub is about 200 bucks and you will see substantial labor involved too so plan on about 500 bucks or better if you cant fix it yourself. Id be looking to Maytag for some help with the cost or get a new machine instead unless you can do it yourself. With the Neptune Class action suit you may just be in time to get a claim in before its too late.
Bearings were not covered under the CA suit so don't bother.You may be able to get some help from Maytag cust service,if you live in an area w/Maytag Factory service available they usually charge a flat labor rate + parts. 800-4maytag. Probably the least expensive way to go.
