Kenmore 70 Series not draining
5 replies to this topic
#1 Pro Car Washer
Pro Car Washer
  • 3 posts
Posted 26 May 2005 - 12:17 PM
I bypassed the lid switch like I read on here and I even manually made the solenoids activate the  drain pump and it wouldnt hold and sometimes locked up the belt. I would run the belt to free it up and it would agitate again. But still no draining. Any ideas?
#2 Pegi
Pegi
  • 13,120 posts
Posted 26 May 2005 - 12:45 PM
Without a model number not sure what you are talking about but if this has a belt ,by-passing the lid switch would not have anything to do with draining.  The lid switch in the belt driven only come into play for spin, but the washer has to drain before it will spin, will not spin with water in the machine. You have a bad water pump sounds like on this at least 20 year old washer.  Might help to ask before starting to follow advise on other styles of washers??  Activating the agitate and spin coils manually is a sure way to lock up the transmission... ;)
#3 Pro Car Washer
Pro Car Washer
  • 3 posts
Posted 27 May 2005 - 01:59 AM
Thanks. It is a 1984 model. Looks like its time for a new one.
#4 FatMan
FatMan
    Sōhei
  • Appliantologist
  • 233 posts
Posted 27 May 2005 - 03:08 AM
Replace that pump, belt and the wig-waq while your at it, just enter the make and model # at the bottom of this page and the parts will arrive quicker then a flick of a squirrels tail
#5 Pro Car Washer
Pro Car Washer
  • 3 posts
Posted 29 May 2005 - 09:55 AM
Pump was $42 and its working like new. thanks for the help.
#6 Pegi
Pegi
  • 13,120 posts
Posted 29 May 2005 - 11:31 AM
Welcome...........;)
