frigidaire frozen refrigerato
8 replies to this topic
#1 dimitrin
dimitrin
  • 3 posts
Posted 27 May 2005 - 02:48 PM
My 3 yr. old frigidaire is freezing the refrigerator. I've turned the refrig. temp control knob to "0" and it still freezes. I've turned both control knobs to between 1 and 0 and it seems to help, though now I think the freezer is not cold enough.
 Thanks for any input!
#2 kdog
    RoughShod
  • 7,428 posts
Posted 27 May 2005 - 08:07 PM
side by side??  top mount?? model ??????????????????????:shock:
  • 24,321 posts
Posted 28 May 2005 - 04:41 AM
Model number help here:
http://fixitnow.com/...ommandments.htm
#4 Pegi
Pegi
  • 13,120 posts
Posted 28 May 2005 - 07:39 AM
Sigh........
#5 dimitrin
dimitrin
  • 3 posts
Posted 28 May 2005 - 01:02 PM
thanks for the quick replies. the model # is frs26f5a and it is a side by side. turning both knobs to between 1-0 did defrost the freezer:(. have now set it  freezer 3 (factory setting) refrigerator 1/4 (almost 0).
 Thanks again for the input here:D
#6 dimitrin
dimitrin
  • 3 posts
Posted 30 May 2005 - 08:37 AM
Anybody there? Help. Please?
#7 Pegi
Pegi
  • 13,120 posts
Posted 30 May 2005 - 09:02 AM
I am not familure with Frigidaire Ref's however there will be those in there that are, but most are probably closed for the Memorial weekend.  You may need to wait till they re-open after the holliday, sorry.
#8 Mad Mac
Mad Mac
  • 1,432 posts
Posted 30 May 2005 - 09:37 AM
There were known issues with these which caused exactly the problem you desctibe, necessitating replacement of the complete control/damper unit. Can you post a serial number as well (located under the model number, should be two letters and eight numbers)?
Mad Mac....Pray to God he's out there....somewhere.
#9 kdog
    RoughShod
  • 7,428 posts
Posted 30 May 2005 - 08:03 PM
start by closing the small door that is located at the bottom of the r/c compartment beside the meat pan/crisper- someone may have accidently pushed the lever to the fully open position.
