noisy dryer
2 replies to this topic
#1 perch38
perch38
  • 2 posts
Posted 27 May 2005 - 05:41 PM
I have a ge washer dryer combo. i had it about 2 years now. the dryer has started making a noise like you were drying a pair of sneakers in it.the noise gets loud then soft after a while then loud again. when i turn the tumbler i barely hear it. also the tumbler wobbles up and down (it has play in it) is that normal? are the bearing gone in it? whats the problem. thanks in advance .also i look at the faq's on noisy dryers nothing seemed to help me
#2 Ron
Ron
    Kohai
  • 368 posts
Posted 27 May 2005 - 06:19 PM
Perch,  sounds to me that your drum support bearing broke,  it's a nylon piece that the shaft support rests in when turning.  It's located at the rear of the dryer.   To replace this the top and front must be removed.  The belt taken off and the drum lifts up from the support.  Then the support bearing is replaced along with the bearing bracket.  You would have to inspect the shaft support to see if it's ok,  this is what rests in the bearing support and mounts to the drum,  but you should be ok with this.  For an experienced tech,  its not too hard,  just depends how mech.  inclined you are.  Part # are....drum support bearing  WEO3x1002.   Bearing bracket....WE13x10009.   Shaft support if you need it...WE13x10011...Ron
#3 perch38
perch38
  • 2 posts
Posted 28 May 2005 - 12:33 AM
so the play shouldnt be in the tumbler right
