Kenmore 106.52254100 Icemaker Problems
#1
Posted 28 May 2005 - 12:25 AM
We are replacing rhe water intake valve at the back of the refrigerator. We haven't turned the ice maker on because we are also replacing the valve at the water shutoff in the wall.
I see posts to replace the water valve,and check the water tube in freezer for blockage.
Any other thoughts as to what we can do? Also: the off/on slide on the right side of freezer wall: is that LED supposed to be red? We were told by our local appliance parts store that it was just a signal on whether the freezer door was open or not and would not be something we could see.
Thanks in advance for any help.
#2
Posted 28 May 2005 - 08:02 AM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#3
Posted 28 May 2005 - 09:31 AM
#4
Posted 28 May 2005 - 01:06 PM
#5
Posted 28 May 2005 - 07:50 PM
But I am still interested in kdog's description of the led module. I gather that this sends a beam across the ice bucket when the freezer door is closed to keep an eye on the level of ice cubes in the bucket? So if the signal makes contact with the other side, does this signal the ice maker to start making more ice? At any rate, what I'd like to know is if this is supposed to be lit. Right now there is no light of any kind. I see by your post that a blinking light indicates software series (do I need to know which is for my model?) and that a steady light indicates need to replace. I never noticed this before, so I don't know what I missed in terms of blinking lights. All I know is that it has no colored or any kind of indication that it is on. Is this broken as well?
Thank you!
#6
Posted 29 May 2005 - 09:59 AM
Clicking on the PDF icon at the bottom left of this page will enter you into the wonderous delights of your in-door ice system. Read, learn and enjoy these 48 pages. Pegi
#7
Posted 30 May 2005 - 08:48 AM
#8
Posted 30 May 2005 - 09:08 AM
#9
Posted 31 May 2005 - 08:19 AM
#10
Posted 31 May 2005 - 11:19 AM
#11
Posted 01 June 2005 - 03:46 PM
#12
Posted 01 June 2005 - 05:36 PM
#13
Posted 01 June 2005 - 09:46 PM
#14
Posted 02 June 2005 - 07:23 AM
#15
Posted 08 June 2005 - 10:02 PM
This morning, I did another jump from T to H, and also disconnected and reconnected the wiring harness.
The jumper didn't force a harvest. But a short time later, the Harvest started up, and we have been getting ice steadily now.
I am keeping my fingers crossed.
Just wanted to thank you for all of your help.
#16
Posted 09 June 2005 - 03:45 AM
#17
Posted 09 June 2005 - 06:58 AM
#18
Posted 09 June 2005 - 09:25 AM
#19
Posted 09 June 2005 - 09:40 AM
