Kenmore Gas Oven Model 103.3247891
#1
Guest_screemn_*
Posted 28 May 2005 - 03:01 AM
#2
Posted 28 May 2005 - 07:56 AM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#3
Posted 28 May 2005 - 09:18 AM
#4
Guest_screemn_*
Posted 28 May 2005 - 01:36 PM
The oven does have a timed bake, and I will take your suggestion and see if I can trace where it fits in with the overall wiring scheme and bypass if possible. Thanks a lot for the suggestion.
#5
Guest_screemn_*
Posted 28 May 2005 - 01:42 PM
Sorry, should have only read "thermostat" w/o the word "valve." But should you not be getting 120V from the wires going to the ignitor? Doesn't the gas valve only come into play after the ignitor heats up to a certain point and resistance drops to open the gas valve, or does the gas valve actually play a part in completeing the circuit prior to opening and allowing gas to enter?
#6
Posted 28 May 2005 - 04:05 PM
If you're only getting 15 v to the ignitor, then you start here and troubleshoot back until you find where you're losing the voltage. Not sure what harness you're talking about but, in general, it's possible to have back connections at harnesses.I went back to the ignitor, removed it, and got a voltage reading from the two wires going to the ignitor of 15V with the thermostat turned to 350 degrees. This oven has no electronics, but I am convinced now the problem was and has been not getting 120V to the ignitor. I have checked and am getting 120V to the incoming plug and going out the other side of the plug where the wires run to the gas valve - ignitor - and thermostat.
Post your wiring diagram and we can point out specific things to focus on.
#7
Posted 29 May 2005 - 03:34 AM
If you never have used the time bake feature and have no idea how it works there is a good chance that at sometime when the unit was being cleaned or kids maybe turned settings.
Usually it will say somewhere on the clock time bake settings, "Push for manual bake", both start and stop times will usually be at same time as the actual clock then one of the clocks, usually the start time has to be pushed in for manual bake.
Eureka, CA 95501
#8
Guest_Huejorg_*
Posted 24 July 2006 - 04:43 AM
#9
Posted 24 July 2006 - 09:27 AM
#10
Posted 08 August 2006 - 11:08 AM
