kenmore coldspot
10 replies to this topic
#1 Guest_leelee_*
Guest_leelee_*
  • Lurking at the Threshold
Posted 28 May 2005 - 02:24 PM
:Dhello all master appliantologists!
   I would love to be a master anything, but I apprecaite all of you. What a great website!
  Anyway, I sold my house a few days ago, so I thought it may be time ot fix the leaky frige! I saw the pictures and diagrams on this website and i am thinking that i need to remove the plastic/styrofoam cover in the back of the refrigerator so that I can clean out the drain cup or drip pan. My problem is i can't figure out how to get that thing off without breaking it! HELP?!? Any advice would be appreciated. I really can't pass on this problem to the new owner.
                Thanks~ leelee
  • 24,296 posts
Posted 28 May 2005 - 03:57 PM
Post your model number and we can help you.
#3 Guest_leelee_*
Guest_leelee_*
Posted 28 May 2005 - 04:50 PM
;) Sorry!  The model # on is 9651753
                                              Thanks again,
                                                leelee
#4 Guest_leelee_*
Guest_leelee_*
Posted 28 May 2005 - 06:12 PM
:? Okay, master appliantologist, please forgive me for not reading the 10 commandments of model number finding.  Here is the correct model number (I hope).  106. 9651753
        :D leelee
#5 Guest_leelee_*
Guest_leelee_*
Posted 31 May 2005 - 05:39 AM
Help!!! please!!! If anyone has any ideas on how to remove the air diffuser cover on a kenmore coldspot model # 106.9651753.  The back of the air diffuser and top two rectangular holes drip water every few days.  I really need to fix it right away.  Any advice would be appreciated.    Thanks, leelee
#6 Mad Mac
Mad Mac
  • 1,432 posts
Posted 31 May 2005 - 06:49 AM
Best way to attack this is to remove the bottom panel (item 25) and the panel in the back of the freezer (item 16). Chances are that you have a blocked defrost drain, which you will see underneath the evaporator (in the back of the freezer).
Mad Mac....Pray to God he's out there....somewhere.
#7 Guest_leelee_*
Guest_leelee_*
Posted 01 June 2005 - 06:00 AM
hello Mad Mac!
   Thanks a million! I really appreciated your help and the time you took to send a diagram. I did everything you said to do. Now I have a few questions...
   Was I supposed to clean out that sheet of ice that was under the bottom panal?
  Is the drain the hole that's in the back that opens up to the refrgerator?
  There was a a piece of plastic that looked like a block in that hole, but it was a part that belonged there just maybe pushed out of place so I moved it.  ???
 I also cleaned the ice out, in the way back on the silver part that the drips flow down onto. Was that the right thing to do?
I am obviously not an appliantologist, but I like that word!
                                            Anyway, thanks again.  I hope the problem is solved and I hope I didn't create a new problem.:yikes:                        If you can let me know that would be so wonderful.
        :D    your new friend,    leelee
#8 Mad Mac
Mad Mac
  • 1,432 posts
Posted 01 June 2005 - 07:21 AM
The drain is the hole in the middle of where the water drips into. This needs to be clear, then the defrost water will run down to a pan on top of your compressor.  The sheet of ice under the bottom panel is just another symptom of the same problem, you should clear that out.
#9 Guest_leelee_*
Guest_leelee_*
Posted 02 June 2005 - 02:49 PM
Hello Again~
   The ice in my freezer is just continuing to bulid up again under the bottom panal after I removed what I thought was blockage.  What i did was I moved a piece of plastic ,that is a part in the drain hole, out of the way. Was this maybe part of the drain? I also removed all the ice.
I waited a few days and it is still leaking.
Is there any way I can check the drain cup to see if the is the problem? Is there something else i can do at this point. What would you all do?
        leelee
#10 Pegi
Pegi
  • 13,120 posts
Posted 02 June 2005 - 03:50 PM
Run something long and skinny down the drain hole and pour hot water in there till it runs out into the pan underneath the box. Until this drain is clear, you will still have the same problem.
#11 exsearsguy
exsearsguy
    Kohai
  • 314 posts
Posted 02 June 2005 - 09:37 PM
Leelee, you might try tilting your box back towards the wall.Possibly the water is seeking it's own level, and you want it to run downhill.
