Hotpoint CSX24XJ Refrig. not so cold
#1
Posted 28 May 2005 - 03:12 PM
There is a small amout of frost on the back wall of the freezer about mid way down and on the fridge side (side by side)
The fan in the freezer is running.
Can anyone help me?
Thank you!
#2
Posted 28 May 2005 - 04:01 PM
#3
Posted 28 May 2005 - 04:15 PM
I am defrosting it now. Is something causing this or is is just old?
#4
Posted 28 May 2005 - 06:45 PM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#5
Posted 31 May 2005 - 05:06 PM
Where is the def. timer located? How can I test it. Any way to manualy turn on the heater to see if it is working?
thanks,
#6
Posted 31 May 2005 - 06:23 PM
#7
Posted 31 May 2005 - 06:36 PM
I think I found the timer. Is it under the frezer behind the kick? I turned the screw till the fridge went off. It stayed off for a while then came back on. It did not defrost though. Heaters never came on. hope this helps narrow the search??
Thanks again
#8
Posted 01 June 2005 - 05:25 AM
#9
Posted 01 June 2005 - 06:28 AM
I will check as soon as I am off work
#10
Posted 01 June 2005 - 06:38 AM
#11
Posted 01 June 2005 - 07:05 AM
#12
Posted 01 June 2005 - 07:17 AM
