Learn how to troubleshoot like a Master Samurai Tech...
Guest TIM C.
Maytag Atlantis Washer
4 posts in this topic
All ready replaced belt did not llok bad but was a crap shoot.Took apart again this weekend all drain hoses clean and clear sat in basement thru full color cycle no load all water drained out ok.Timer appears to be advancing normal.Did notice white fiberglass or plastic filings under tub transmission assembly.If something was not right in the tub assembly tranny would this cause drainage problems
Does the motor run during spin?  Does the pump rotate?  If yes, then you've either got something stuck in the drain hose or you have a stripped out pump.
Yes the motor runs during spin cyclye and pump spins because the water drained and i could here it running down the drain.Of course not every load is soaking wet at the end.This has been an intermittent problem.If the pump was stripping out would larger loads effect operation.What i mean is would it slip sometimes and not others
Pull the drain hose off from the pump and blow through it from that end-- should be free and clear.  Then pull the suction hose off the pump and see if water flows out from it freely.  Lastly, check the pump itself for obstructions.  The problem is in one of these places.
