Guest gil
kenmore series 80
3 posts in this topic
I have a kenmore dryer (model #110.70802990) that quit heating properly.  I went on the roof and cleaned out the vent stack with a shop vac.  Lots of lint came out.  The air temp coming out of the stack was fairly warm (I held my hand over the opening) but suddenly went cold.  Thinking a breaker tripped, I reset all the breakers.  Air temp still cold.  Later that evening we began to smell gas around the dryer.  I shut off the gas valve to the dryer.  Looking thru you site, I see a lot of possibilites.  I am hoping you can help me narrow the problem down, especially the gas smell.
Gil,  I would pull the vent from the wall and make sure that is cleaned out as well as the roof vent.  Check your gas line connections to the dryer for leaks.   Run the dryer with the vent off and make sure there is a good air flow comming from the vent.  See if the dryer heats normally with the vent off.  If it does,  you know that it was a venting problem.  Make sure your doing this on timed dry.  If the problem still persists it could possibley be your coils on the gas valve.   Check the aforementioned first and let us know...Ron
Guest
This topic is now closed to further replies.
