Whirlpool ice maker problem
Started by willin2try, May 29 2005 07:48 AM
3 replies to this topic
#1
Posted 29 May 2005 - 07:48 AM
I have a whirlpool side by side, ED25PSQDW00, that I purchased in 1997 (it was manufactured in 1996). I had bought the extended warranty (which has since expired) and had repairs done to the icemaker which has the module. The module has a date code of 2001.
Anyway, no more ice. I took off the the cover to the module and jumped T to H. The round dial on the module rotated. I jumped V to L and heard a whirring noise (but did not hear any water flowing). Any suggestions on the problem or what else is should check? Also, when I jumped the wires, is there any length of time they should stay jumped? Should the ice maker bar be in the ice making (down) or off (up) position position when I jump the wires?
Also, I notice that there is a company called waterfiltermart.com that appears to have an icemaker for $59 and the module for $55 which seems like a good price if that is what I need. Has anyone ever heard of them? Also, am I correct in assuming that If I buy the icemaker, it will have a module built into it already so that I do not need to buy both? Thanks.
#2
Posted 29 May 2005 - 12:31 PM
I would be checking the fill valve first and check to see if the thru tube to the ice maker is clogged with ice. Take a test cord to the valve to see if it is giving good water flow. Sounds like a no water to the ice maker problem. If you want parts why not just order them here? Where you are getting FREE HELP to your questions??? Will this other company let you return these parts if it is not your problem??? Do they give free advise??? I would think not.......
Buy your parts here!
Read More
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#3
Posted 31 May 2005 - 04:39 AM
Go to LOWE'S and get an icemaker kit. $49.99:party:
#4
Posted 31 May 2005 - 04:45 AM
drjew- be sure to go to lowes next time you seek some free advice!
