FPSteve1
Fisher & Paykel GWL10 washer not draining
33 posts in this topic
Me again from the msn site...
Recap and update: GWL10 washer recirculates water but won't drain: tub full of water at start of rinse cycle, machine recirculates awhile, then beeps with code #37 "Pump blocked error " , but pump and drain not blocked. Again, it just recirculates, even with Drain Pump Test. No clogs anywhere.
Essentially, the diverter valve isn't switching to drain.  Although no obvious broken parts on the outside, replaced diverter valve with a new one from F&P (now with protective hood- fancy!) - no change in problem, but at least only spent $17.
Have 120v going to pump and diverter valve during pumpout, both up in control panel and at pump and diverter valve themselves. NOTE: when wires are removed from diverter valve during pumpout/rinse cycle, diverter valve allows machine to drain out drain pipe.  Plug it all back together, and valve closes to drain pipe and machine recirculates again.
Are we now looking at the motor controller module for bad signals?
Try it on Permanent press and see what happens.
It shows that the diverter is at "recirculation state" when powered (ON) and at "drain state" when un-powered (OFF).
Check the switching device of the diverter: by relay or by power-electronic device(triac or SCR).
You may have to get the circuit diagram of this washer. F&P usually uses power-electronic device to control the washer motor.
a) If by relay, the relay may be stuck "ON" due to melted contacts.
B) If by power-electronic device, the device may be burnt and short-circuit.
c) If the switching device is good, then trace the cause back to the electronic control board.
Same thing happens on Permanent press.
I'm assuming the diverter valve switching device is good, since I replaced it with a new one and still having the same problem.
Pump control in this model has changed.  The pump cycles on and off every 10 seconds during the initial (60 hz) pumpout.  Do you hear this happening?
In this model, the pump is part of the switch mode power supply so if the pump thermal overload opens, you'll lose power to the control module.  You can measure this.  Is this happening?
It sounded that you have replaced the diverter valve AND its (electrical/electronic) switching device.
If so, is the switching device a "relay" or a "power-electronic device (triac or SCR)"?
Samurai - Yes, it's cycling every 10 seconds, and if I'm measuring correctly and at the right time (just a Grasshopper here) it's losing power to the control panel.
Seven- not sure how to tell if the new switch is relay or not. Just popped open the old one, and the round silver disc inside and plastic casing next to it appears burnt.
Hooold on there, Bubbalouie! You say you ARE losing power to the control board? If so, then that's the problem.
I think so. Again, I may be measuring at the wrong place or at the wrong time, or have something disconnected.  I'll get in there again.  When exactly in the cycle and where should I measure?
If I am checking correctly, and it's losing power, then it's still the pump that needs to be replaced?
That is correctum! :dude:
did you have the sheet for diagnostic mode if not heres one for you
GWL10.pdf
My F&P GWL10 wont drain and it appears to be the diverter valve. One authorized repair place said I should get the instructions over the phone on how to clear the pump from the authorized repair company located closer to me.  They apparently want $250 to come and tell me this personally.  I downloaded the PDF file with the diagnostic mode instructions and forced the pump-drain mode, but it only recirculates.   I do not see the details about testing the diverter valve [other posts mention testing the diverter valve specifically].  If you have that information I can try and verify if that is the problem.
We finally gave up and took it to the shop - diverter valve just wasn't working, and I got zapped trying to keep testing it during different cycles.  The problem was the motor controller module (about $130  for this model,) which also fried the new diverter valve we had put in.  New parts and labor were $300.
Bummer deeude. :java: But, hey, it's fixed. And thanks for the update!
Samurai, you are a god!
I think the diverter valve would have been fixed sooner, but F&P did not ship the part in time for the weekend.  No problema there.  Took your advice and had quite a few beers, sent the wife to the laundromat and had a very relaxing weekend [so peaceful!].
Unless I am mistaken, the connections to the diverter valve are not polarized [note the AC 50/60 Hz stamped on the actuator]  Just in case, for reference, I put the black wire closest to the side of the orange actuator with the  part information i.e. 50/60 Hz and all is well.  For those that missed the post about the default mode of the actuator [wires disconnected] it should be switched to DRAIN the tub.  Unfortunately, my diverter valve failed due to a build up of hard water and/or other various crud and the small plastic piece that joins the actuator and the small lever that moves the valve was broken by the force trying to push the stuck valve.  In case you did not take detailed notes on the direction the valve was installed, look inside the valve and the path that is open on the valve connects the tub and the drain hose.
Before buying the valve, you should be able to disconnect the orange and black connector from the top, under the panel [turn off power first, of course] and valve should be in drain mode and not re-circulate.  Enter diagnostic mode, press "regular" to initiate pump and you should be draining.  If not, valve may be broken, or possibly plugged
FPSteve1 appears to have spent more than six months trying to fix his (original post in April, and "took to shop" in November)
WOW, that's persistent!
No awards here.   We actually got it repaired in June, but it did take almost 2 months by the time we waited for parts, tried new things, bailed out the washer a hundred times, etc..
Good learning experience tho, and really enjoy reading The Samurai's website (and drinking beer.)
I am resurrecting this thread!  I have the same problem with the diverter valve not draining but continually recirculating.  When I first found the diverter valve I noticed that it was getting very hot to the touch.  I also noticed that as soon as the unit is plugged in the little elctronic plunger very s l o w l y came out and closed off the drain.
I thought that it didnt seem right that it would open so slowly AND be super hot so I ordered a new valve thinking it would solve all of my problems and eliminate hunger throughout the world.  You can tell from my sarcasm that I was incorrect.  =(.  Since I ordered a new valve I decided to dissect the old one.  The little siler button inside was very burnt looking, further confirming my suspicions that the diverter valve was bad.  Oh yes, before I go on, there was nothing stuck in the valve or any broken bits.
So, last night I replaced the valve and plugged it in.  Same thing happened.  The plunger slowly creeped out closing the drain and the actuator got hot.  I ran the cleaning cycle just to see and sure enough, I can hear the pump cylcing every 10 secs and only recirculating the water.
Where do I go from here?
The motor controller is sending power to the DV. You'll need to replace the MC.
The MC is not repairable I assume?
Fortunately for me, I live in SoCal so shipping is pretty quick.
Thank you for the quick response.
I have entered appliance repair purgatory.  F&P GWL10 has served us well for 5 years but I have a problem now that has me at a point of frustration and defeat.  We originally bought the F&P to fit a smaller space in a duplex and I had no idea about the difficulty of locating parts anywhere or getting service in a rural area.   I am writing this post primarily to help others avoid the same mistakes I have made this week.
Washer originally would not drain.  Same symptoms as top of this post.  Found the the diagnostics sheet in the top of the control panel.  Tried all suggestions plus others (unplug machine, unplug diverter valve, unplug drain pump, diagnostics, let sit, etc.).  Couldn't get anything to reveal.  Even checked drain pump although water was pumping and recirculating at the point it would not drain.  After trying several times, machine stopped powering up altogether.  Unplug, wait 60 seconds, plug in and display controller only flashes.  I now feel that sinking feeling that I have made matters worse.  (First mistake)
Called our appliance service man.  Didn't realize he was not F&P factory authorized which means parts he buys and not warranted any more than if I buy them direct.  Of course he doesn't have the service manual either.  (Second mistake).  He tries calling New Zealand and didn't even know parts are available from California.   By the way for the uninitiated, F&P parts not generally avaliable locally and must be shipped from CA which takes several days unless pay an extra $25 for overnight delivery.
After reading posts and understanding how the diverter valve works, I assumed I had a diverter valve problem that was simply stuck.   Took off hoses, valve felt stuck, pushed on it and broke the gray plastic arm.  If you are at this point, take the diverter valve off of the machine and look and how it is made before you start pushing on things.  Anyway, it is now broken but I don't have power so I still don't know if it is the diverter valve or not.   Of course, laundry is starting to pile up and wife is becoming very unhappy.
From this posts, learned it may also be the motor controller.  Couldn't find the diverter valve locally but just happened to find the motor controller from a local service company.  Took a chance and bought it (cost $133 total), plugged in and no difference.  Board still flashes briefly.  Now I wonder if I have burned up a second motor controller.
So I now have a machine that won't power, a $65 service bill, a controller that I can't return, and a broken diverter valve.  Anyone have any ideas or suggesitons on why I can't get the power to come on.  I assume it is not the display controller because it was working just fine and another post indicates those usually do not cause problems.
Is there any way to check anything more or is it time to throw in the towel (pun intended)?  We have the matching dryer so I would pay a few more bucks even though it is probably not worth going further, but a man's pride is worth something. I usually am pretty good at making repairs on my jeep, outdoor power equipment, and even appliances but this one has the best of me so far.
Unfortunately I didn't discover this site until several days of "experimenting."  Had I known about it, I would have gladly paid the one time fix it fee.   If anyone who is reasonaly mechnical finds this post and is in a similar situation, I would highly recommend  paying the fee for the help before you ruin other parts and further delay the repair.  Takes too long to get a part from California only to discover that something else is needed.   To make matters worse, we went to Lowe's yesterday and saw the GLW15 for only $599.
I have always said that hell is a place where the condemned must try to fix trailer lights for eternity (anyone who has ever owned an old trailer understands this frustration).  I now think working on a F&P washing machine will be right there as well.
Hello, I was wondering if you could help. The washer will not drain.  I have a Fisher & Paykel Washer Model GWL10 Ecosmart.  I am getting an error code #37 Pump Block Error.  I have tried unplugging the machine for one minute and attempted to restart the load but when the load gets to the rinse cycle the water just circulates and will not empty into the hose. That is when I get the error code. Additionally, I have tried the Drain Pump Test by pressing there REGULAR button to drain the tub but the water just circulates in the tub. Does this mean that the drain pump is not working or does it mean that the diverter valve is not working.  I have also read postings that it could be a motor controll module.  Where do I start? What is wrong with the operations?    How can I fix this washer?:shock:
Sincerely,
Kurt
I have learned first hand that the problem is either the motor controller board or the diverter valve.  You MIGHT get lucky and replace the diverter valve and all will be well. The diverter valve is only 12 dollars or something small like that directly from F&P.  I was not so lucky.  I replaced the valve and I still had the same problem.  So, I had to replace the controller at 133.00.  Bam, problem fixed.
Good luck
Well I just ordered $200 in parts ($ 22.03 for the divirter valve and $ 144.28 for the motor controll + $25 overnight shipping, and we will see what happens.   I hope this stuff is not diffucult to install.
Can I assume the divirter valve is on the back of the machine or is it unter the machine.
How do I access the motor controll valve?
Does anyone have diagrams?
Regards
Kurt
The diverter valve is under the washer.  You will have to siphon out the water left in the tube and then tip the washer forward to access the diverter valve.  As for the controller it is under the control panel.  You need to remove the 2 screws at the back of the control.  The oanel should come off and then you will have access to the motor controller.  Before removing the MC I would suggest taking a few pictures of the wire and plug layout that way you can look back at the pics while you are reassembling the unit.
Guest
This topic is now closed to further replies.
