Calibrate Control - GE Dishwasher
1 reply to this topic
#1 ammcat
ammcat
  • 1 posts
Posted 29 May 2005 - 02:58 PM
GSD5610DAA00 dishwasher, about 5 years old will not complete cycle when using the "sanitize" cycle.  The dishwasher stops and beeps, beeps, beeps.  The manual says try again, if beeps persist, call for service.
Well I have replaced the sequence switch without success.
Then replaced the control assembly.  GE does not send any instructions with the control assembly.  Is there a calibrate routine needed to activate the control assembly?
I called GE, they will not provide any assistance over the telephone.  Unbelievable, after all it was a genuine GE part purchased - WD21X10116 control assembly.
I have not tried the F1 test, maybe that would calibrate?
Thanks for the help
#2 Jedi Appliance Guy
Jedi Appliance Guy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 691 posts
Posted 29 May 2005 - 05:37 PM
   The force says make sure you pulled the personality harness off the old control and put it on the new control.   A common grasshopper mistake.
