ge defrost timer?
5 replies to this topic
#1 mamoux
mamoux
  • 3 posts
Posted 30 May 2005 - 04:33 AM
i can't seem to locate my defrost timer. i think it needs replaced because the fridge runs too long and the fresh food side doesn't get quite cold enough.  #GE TFF22D side-by-side  thanks
#2 Pegi
Pegi
  • 13,120 posts
Posted 30 May 2005 - 08:30 AM
Need the rest of the model number to be sure, get it off of the ref., probably down above the toe panel on the right side by the hinge side of the food compartment door,  not the paper tag on the door or the book that came with the frig.  Look to see if the back panel inside of the freezer side has frost or ice on it, if so remove the bottom back panel inside of the freezer and see if it is clogged with ice.  You could have a bad defrost timer, heater assy or bi-metal or a combination of the 3 if the defrost system is out. The heater is under the evaperator, the bi-metal is at the top of the coil and the defrost timer is behind the toe panel you remove to clean the condensor twice a year, mounted to the frame behind a metal bracket on the freezer side. If the freezer is clogged with ice, turn the defrost timer to the right slowly until you hear a louder click and the box goes dead except for the light, then wait 3-5 minutes to see if the heater gets red and hot.  If it does this tells you the heater and bi-metal are ok, and the timer is bad.  If they do not come on you could have a bad bi-metal and/or a broken defrost heater.  They are glass so may hve failed.  If you cannot turn the timer, like it is seized up, you know you will need this timer, at least.
#3 mamoux
mamoux
  • 3 posts
Posted 01 June 2005 - 04:30 PM
thanks for your help. I defrosted the refrigerator and manually turned the timer also. It is now cooling great  and sems to cylclingthrough fine.i will come here for any future help. Once again thanks.
#4 Pegi
Pegi
  • 13,120 posts
Posted 01 June 2005 - 05:44 PM
Yes, it  will cool fine now for a few days till it ices up again,  Watch the temps as that air flow will be blocked again as the ice gets thicker on the evaperator.
#5 mamoux
mamoux
  • 3 posts
Posted 02 June 2005 - 04:04 PM
Why is it going to ice up again for sure? I have a tempature gage inside the frige i guess i will watch it for a rise in temperature.  If the temp starts to go up what would be first plan of action?
#6 Pegi
Pegi
  • 13,120 posts
Posted 03 June 2005 - 04:40 AM
You removed the problem but not the cause.  It froze up because the defrost system has a problem.  Either the defrost timer is not advancing, the bi-metal is bad or the defrost heater is broken or a combination of the three.  You will want to turn it into defrost while the box is cold and see if the heater comes on.  If not you would replace the heater and bi-metal.  If it does come on you will replace the timer.
