replacing a run capacitor?
jerome8283
Is there anything other than turning off the power, pulling the disconnect, disconnecting the old run capacitor and discharging it and connecting the new that must be done to replace a run capacitor?
Secure it so it won't bounce around and potentially ground one of the terminals.
 When replacing a capacitor, ideally use the same micro - farad rating, and voltage. You can use a higher rated voltage rated capacitor, with no affect of operation, but do not use lower voltage. It will probably fail over time. When discharging a capacitor, ( previous  to checking it ) most people just short it to ground. However, this may cause the capacitor to fail. Use a small jumper wire, attached  with a resistor, 10K resisitor / 1 watt, normally works fine .:)
  • 4 weeks later...
