loud noise during spin cycle
7 replies to this topic
#1 margaret
margaret
  • 2 posts
Posted 07 April 2005 - 08:21 AM
My GE profile washing machine makes a very loud sound when spinning.  I have replaced the 4 dampening straps as 2 were broken.  any other ideas as to what area I should check?  thanks.
#2 Mad Mac
Mad Mac
  • 1,432 posts
Posted 07 April 2005 - 10:34 AM
What kind of noise? Thumping, screeching, screaming like a detoxified Samurai? ;)
Things to check:
Open the front, any signs of oil and/or water leakage inside?
Does the basket spin freely while agitating (it will move slightly, this is normal - I'm talking about more movement)?
Mad Mac....Pray to God he's out there....somewhere.
#3 Jedi Appliance Guy
Jedi Appliance Guy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 691 posts
Posted 07 April 2005 - 05:14 PM
This reply undergoing renovations.  When this header is gone renovations will be complete
    The force is telling me your washer is toast.  You may continue to use it for a short period while you shop for a new washer.  It will only get worse and eventually leak or even flood.
     We must now confirm what the force is saying.
Remove the front panel.  Look on the inside of the panel near the floor.  does it look like this?
Start a wash, with the panel removed,  Lay on the floor and look at the center of the bottom of the tub.  Do you see water or signs of it?
If so you will need these.
WH38X10002 Transmission
WH2X1198 Hub Bearing (oil impregnated bronze sleeve bearing)
WH2X1193 Hub Nut
WH43X10009 Air Bell Coupling (use only if old one is stuck)
WH02X10037 Screw
This is the basket with the agitator removed.  You can see the airbell coupling.  Notice the rusty 7/16 bolt
I use a claw hammer to remove the air bell coupling.  If it's stuck I break it in half.
 This is my assortment of spanner wrenches.  The one in the middle is almost univeresal.  The GE wrench on the bottom has seen lots of force
This is taken with the basket removed.  You can get rid of the remaining water now or off the floor later.
Notice the sticker on the front of the tub.  Notice the motor goes in the front.  It is possible to put this back together backwards.
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/197229/149875321.jpg
Another Special tool.  I think its called a pulley holder.
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/197229/149876222.jpg
Removing the tub seal.
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/197229/149876328.jpg
I use a 1/4 ratchec extension to push out the old tub bearing.  I don't hit it hard. I just let the hammer fall.
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/197229/149876529.jpg
I aways replace the tub bearing.
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/197229/149876631.jpg
  The 1/2 way mark.  Notice I dragged it outside on the grass.  You don't have to clean up the crud like you would if it was inside on the floor this way.
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/198211/150959126.jpg
Don't forget this
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/197229/149876832.jpg
Leave the tape on the brake.
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/197229/149876933.jpg
The proper way to handle the new seal.
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/197229/149877035.jpg
I use the same extemsion to push the edges of the seal in place all around.
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/197229/149877136.jpg
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/197229/149877237.jpg
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/197229/149877341injury.jpg
02X10032 Tub seal, WH2X1193 Hub Nut, WH43X10009 Air Bell Coupling, WH02X10037 Screw.
http://groups.msn.com/isapi/fetch.dll?action=MyPhotos_GetMBPhoto&ImageID=nEQAAAFoG3jT7iqPfPpbynFeGGWu1UHPytdIS2aQFTjAh4RKDyZdb9g
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/197229/149877443.jpg
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/198211/149893944.jpg
http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/198211/149893645keeptheairin.jpg
  • 24,348 posts
Posted 24 April 2005 - 06:17 PM
:jedi:
#5 Mad Mac
Mad Mac
  • 1,432 posts
Posted 24 April 2005 - 06:43 PM
I'm getting all nostalgic now...memories of many GE transmissions.....:gulp:
#6 badchade
badchade
  • 2 posts
Posted 08 June 2005 - 12:50 PM
UNBELIEVABLE!!
After 2 hours of trying to get a GE tech to tell me how to remove the air bell coupling, I finally did some searches and found this thread.  Jedi's picture post was exactly what I needed(looks like the same model too!)
I'm going to head downstairs armed with my new Jedi knowledge.
rePAir It I mUST!
Chad
#7 badchade
badchade
  • 2 posts
Posted 08 June 2005 - 09:16 PM
Now...If only I could get ahold of one of those special tools to get the big nut off...That's where my problem is now.
Chad
  • 24,348 posts
Posted 11 October 2005 - 01:01 PM
We gotta get Jedi to give us the finishing touches on this excellent how-to thread! :jedi:
