Kitchenaid Microwave door spring
2 replies to this topic
#1 Dales
Dales
  • 5 posts
Posted 24 July 2006 - 05:09 AM
I havea a Kitchen Aid Supera Oven/Microwave combo.  Model # KEMC308KSSO.  My problem is the spring for the microwave door broke.  How hard is this to replace?  Is it something I can do myself or is it something I should call a tech for.
thanks,
Dale
#2 sfodom
sfodom
  • 3 posts
Posted 25 July 2006 - 05:46 AM
I replaced mine myself.  Only problem I had was that I dropped the door faceplate while removing it.  There are only two screws holding it on from the inside, once you remove those two screws the faceplate will fall off.  The spring is a torsion spring located in the bottom of the door.  Can't remember where I bought it, but it should be easy to find.  Ah, is this your part?  http://www.easyappli...&RefineSearch=0
Page 2 part number 16
or this   http://www.repaircli...ccPartID=589688
Sue
#3 Dales
Dales
  • 5 posts
Posted 10 August 2006 - 02:32 AM
Thanks for the info.  I'm going to order the part and give it a try.
Dales
