Kenmore DW won't drain and leaks on floor
1 reply to this topic
#1 Guest_rbboom_*
Guest_rbboom_*
  • Lurking at the Threshold
Posted 07 April 2005 - 02:43 PM
I have a dishwasher (665.17765891 kenmore) that quit draining and leaks on the floor.  I believe the water is coming from the door, I assumed because of the standing water inside.  It never leaked previous to the draining problem.  How and were do I check to fix the problem?  Thanks for your help
  • 24,289 posts
Posted 07 April 2005 - 05:57 PM
If you hear the motor running during the pumpout cycle, then you've got a plugged drain or a crudded up check valve. More dishwasher drainology help here.
