Guest Wolf
Kenmore washer 110 22702 100
6 posts in this topic
the washer turns on but does not go into spin mode or pump the water out.
no leaks, voltage is good
write to me at wolfvid@comcast.net
If it is dead for drain and spin see if your lid switch is broken.
where do I find a drawing of it, or a test proceedure??
is there an overall diagramm how the thing works? a manual? a troubleshooting guide?
thanks
wolf
wolfvid@comcast.net
I have the same problem with my Kenmore 110.92273600.  I was thinking it was the pump, since it is agitating and that if the lid switch was faulty it would not agitate.  Is that not true?  How can I tell without taking it apart and checking to see if the pump is frozen?
:yikes: The Nervous Novice
Do not know if your washer will  not agitate with a bad lid switch.. You would have to look at your wiring diagram to figure that one out.  W.P is going to start making them not agitate with the lid open and then also not even fill..Seeing the age of your washer I would think it would agitate with the lid open.  Put the thing in agitate and look and see if it does  agitate with the lid open, mine does..  if it goes dead after the agitate cycle and will not drain or spin, suspect the lid switch.
