Radiant Burner Cuts off when it heats up
#21
Posted 03 June 2005 - 01:26 PM
#22
Posted 03 June 2005 - 01:29 PM
Le Chien Rouge
#23
Posted 03 June 2005 - 01:34 PM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#24
Posted 03 June 2005 - 06:22 PM
#25
Posted 03 June 2005 - 06:33 PM
#26
Posted 03 June 2005 - 06:36 PM
#27
Posted 03 June 2005 - 06:40 PM
Check the surface controls first to make sure they're set correctly.
Be sure to use flat-bottomed pans that are the right size and shape. Using a pan that's not flat or is too large or too small will prevent your cooktop from heating properly.
If neither of these tips solves your problem, check the voltage to your home to make sure it's not too low
_________________________________________________
one of the answers to questions about your range...
#28
Posted 03 June 2005 - 06:44 PM
#29
Posted 03 June 2005 - 06:53 PM
#30
Posted 04 June 2005 - 05:18 AM
#31
Posted 04 June 2005 - 05:08 PM
check this with a ruler if your pans are not perfectly flat the elements will cycle like you describe. every time i have dealt with this complaint it was because the customers pans were not flat.
