norco1
timer engagement
3 posts in this topic
my coin operated kenmore washer doesn't reach the timer to activate. timer lever stops too far from coin activation lever. how do i move the timer lever back further. i notice a couple of adjustment screws, don't know how or which to adjust. please advise
Was this something that was working then now for some reason doesn't work anymore?
If the above is the case, look in the bottom of the timer box for a coin slide extension that has fallen off.
If this is a new coin slide that you just installed, you received the machine without a coinslide and you just purchased the basic coinslide from someone. Then you will need to get the correct attachments that screw to the end of the coinslide, (The part that will reach down and flip the timer control to on when it slides past it).
With more info about exactly what is going on and a model number we may be able to help you more.
i removed the timer and turned the adjustment screw to the right, closer to the coin trip lever. think i've got it. thanks
