Learn how to troubleshoot like a Master Samurai Tech...
derek zoolander
kenmore wash/dryer combo 417.97802791240
5 posts in this topic
Looking for the starting point on dismantling the dryer to access the heating element and drum rollers . It started arcing and I found the drum was "sagging" need to get under the hood to fix it up, I'm running outta clean undies!!
Derek
this is a fridgidaire built unit and does not contain drum rollers,but instead uses a "trailer hitch" type of bearing in the rear and a felt,teflon glide system in the front- to gain access, you'll need to first remove the power(unplug unit) and remove the centre transition(the metal peice that is on an angle) by removing 2 screws near the top and sliding the panel upward.  then,remove the 2 small black phillips head screws in the bottom of the console endcaps and 2 roberts head screws that are located beside them-the control panel will then lift a bit and flpi forward.  the front dryer panel can then be removed by taking 2 screws from the bottom and 4 from across the top. once the panel is off,disconnect belt and lift rear of drum upward- upon inspection,you will probably find you need to replace the rear bearing and the front glide/seal and if the element is broken or sagging,you will need to replace it as well(visible once drum is out)- all of these parts are available through this website.
Thank you for your time, I will begin after dinner.
bon apetite'
p.s. you can turn the undies inide out for a little extra mileage        :poison:
