  • Announcements
Guest DonnaDoula
Kenmore Dryer Too Hot
48 posts in this topic
I was doing laundry and everything was working fine.  Then...I pulled the dry clothes from the dryer and they were *very* hot and there was an orange glow inside the drum coming from the back of the dryer.  I unplugged the dryer and glow went out.  I let it cool down, plugged it back in, and tried to start the dryer for the next load, it glowed orange again, but wouldn't tumble.
I searched on this WONDERFUL (by the way) site and discovered it probably needed a new thermofuse.  I pulled that and the thermostat (which looked like it had gotten too hot...had a place on it where it looked like the metal had been burned) and took it to the appliance parts store.  They tested them with the ohm meter and they were both bad.
I replaced the thermofuse, thermostat  and the dryer vent hose.  I vacuumed it out, because it had gotten REAL "lint-y" since the old dryer vent hose had come off, and was testing it out to see if it was ok to use.
I turned it on for less than 1 minute and the outside of the dryer got REAL hot.  Like the hood of a car on a 100 degree day.  This can't be right and I don't want to mess up the parts I just replaced.  Do you have any suggestions?  Thanks in advance for your help!
Sounds like your heating element has grounded itself to the dryer, and will never shut off till you turn the dryer off or unplug it.   UNPLUG THIS DRYER NOW, because if this has happened the whole dryer is getting 240 volts fed to it, case and all...
Thanks for the QUICK safety tip.  Dryer is unplugged.
Is there a way I can "unground" the heating element?
usually the element broke and one end is touching the canister or the bracket, you will have to look at the element to see if the coil is touching something.  would need model number to see where it is located for sure but sounds like it is on the back.  remove the rear panel and the element is on th right side inside the silver canister
We just replaced the heating element 2 years ago, but I guess it could have broken (especially if it was overheating b/c of excessive lint?).  Model number is 110.76975140 Kenmore Electric Dryer.
Is the canister w/heating element in it long and skinny?
Yes, if you did not remove the canister to replace the element the bracket would have bent putting the element in.  Be sure to remove the canister from the dryer to replace the element.
Okee.  Will try to do that tomorrow.  Thanks for your help so far!  Will let you know what happens.
Something metal could have also gotten into the canister and is touching the element like a bobby pin or something, thru the air holes in the drum.
I'll look for that.  It's quite possible some foreign metal object is in there.  When I cleaned out the inside of the dryer, I found $0.94, several paper clips, a key chain, a pencil, a small toy, two buttons, and a gold bracelet!  I bought the dryer used, and the bracelet must have belonged to the previous owner.
Do you have information on how to remove the canister?
There is a clip at the top of the canister that attaches to  the plenum with a screw.  Remove the screw and clip, pull the top of the canister toward you about an inch then lift it up off of the 2 L brackets.  Then flip it over onto your lap, remove the screw holding the element in the canister and slide it out and take a look at it.  When putting it back in, there are 2 slots on the canister that go onto the 2 L brackets, then be sure to push the whole assy back into the recess of the back panel.  Be sure to reattach the clip or the canister will fall back and all of the heat will to up into the console, melting all of the wires.   Now, that would not be a pretty sight.......;)
Wow, you're full of helpful information!
What/where is a plenum?  Do you have a picture?
That is the panel the drum rotates around inside of the dryer and the same metal panel all of the goodies mount to on the back of the dryer after the rear metal cover is removed.
I removed the canister and heating element.  Inside I found that two sections of the heating element (curly wire) were bent and touching other sections of the element.  Would that be a probable cause for something metal inside the canister touching something it was not supposed to...making it run extra hot?
Do you have a wiring schematic?  There are two red wires coming off the heating element.  One is connected to a 2nd red wire attached w/a plastic cap and leading to the other wires that are inside the dryer.  The 3rd red wire--the 2nd one coming off the heating element is exposed.  There is a 4th red wire w/a plastic cap on the end of it.  There are no other wires attached to this 2nd plastic cap (wire nut).  Should the exposed red wire be attached to the 4th red wire?
I'm concerned about some bubbles on the outside of one of the red wires.  Sounds like it got too hot?
I think a lot of people have taken a weekend to spend with their families. As you know everyone does this for free just to help everyone that they can.
So be patient if you dont receive a quick reply.
I can tell you what I know on this but Pegi will know much more.
From what you just described the elemnet is bad and needs to be replaced. Yes that will cause it to get too hot too.
The terminals on the element are a tiny bit larger than the ones that will go to the thermostats. So look closely at them and they can and should only go one way. Take your time , put on your glasses and you will see the difference is size of the terminals.
Remember that you are dealing with 240 volts so be very careful as to what you are doing.
Pegi will be back soon.
Sounds like Pegi led you to the problem.  You need to replace the heating element assembly
YOU have the schematic. It's in your dryer.  Do you know how to read it?  You shouldn't need it as long as you're careful to mark what wires go where.
You should cut this wire back to a good part and splice in good wires as needed.  If you don't know how to do this, there are numerous books available on home wiring, even DVDs that can help you.
http://fixitnow.com/2005/01/appliance-repair-revelation-secrets-of.htm
Well, back after diving for cover what with the toronado warning...:shock:  Anyway, the broken curly coils were touching somehing they should not have before you pulled it out of that canister, either the canister or the bracket it was strung in.  If you did not remove the canister 2 years ago, this caused this problem now.  Your element was causing the heat to never shut off, all of your safeties were by-passed, a very dangerous situation.  You are lucky this dryer did not catch on fire.  Replace the element and the damaged wiring and you will be good to go.  The Samuari showed you what you need to order here....;)
Hey, Pegi, glad to see you cheated death another time!  :bananadance:
Hi Pegi!  Glad you're safe.  We're dodging tornadoes tonight here, too.
Sorry for the confusion.  I must have been writing my response when you wrote yours, b/c I didn't see it until after I posted mine.
You said, "the broken curly coils were touching somehing they should not have before you pulled it out of that canister, either the canister or the bracket it was strung in. "  Would it touching itself do the same thing?
Would my straightening them out make it ok to use?
You said, "If you did not remove the canister 2 years ago, this caused this problem now.  "  My (now) ex-husband replaced it.  I'm sure he must have removed the canister to put the heating element in it.  I don't see how he could have done it otherwise.  But that's the reason *I* did not know how to remove the canister.
Thanks again for your help!
I very easily straightened out the curly wire on the heating element so that none of the sections are touching any of the other sections. It looks nice and straight like the one in the picture. Is it ok to still use?
NO - DO NOT USE THIS ELEMENT. Many things I would say okay what the heck give it a shot. But not this. Its has been stretched out and this being bad is far worse than say just a belt or something. FIRE!!! You already have it disassmembled and ready to go. A couple of clicks right here, Order it from here....done! Have it in a day or two and do this right so the chance of the entire dryer burning up is ommited.
You cannot use the element, it is damaged.  It will have to be replaced.  You cannot re-attach the two broken ends.. Twisting them together will only cause the same problem within days or sooner. Your dryer/house is worth more than a new element.  Look at the damage it already did to the wires.  Sleep better at night knowing a new element is in the dryer and be thankful he saw the orange glow and asked what to do and was told to UNPLUG THE THING......:poison:
I think you guys maybe missing what Donna actually said....
"Inside I found that two sections of the heating element (curly wire) were bent and touching other sections of the element"
Her element is not broken, may be able to get away with using the element but as other suggested, for the price and piece of mind, replace it while you have it apart.
Then she goes on to say "There are two red wires coming off the heating element. One is connected to a 2nd red wire attached w/a plastic cap and leading to the other wires that are inside the dryer. The 3rd red wire--the 2nd one coming off the heating element is exposed. There is a 4th red wire w/a plastic cap on the end of it. There are no other wires attached to this 2nd plastic cap (wire nut). Should the exposed red wire be attached to the 4th red wire?"
Obviously one of the wires on that previously replaced elements have broken off at the wire nut that was used to install the replacement element. There is a good chance that that bare wire was touching to the frame and if the leg that was still attached to the element was coming from the timer that would explain the element being on without the dryer running, and probably the reason she hasn't had a fire, when the timer goes to off the element would shutoff if the above senerio where true.
So, "Yes, Donna", that one exposed wire coming from the element should be connected to that "2nd plastic cap (wire nut) that no other wires are hooked to".
The wiring diagram would usually be found glued to the back of the cabinet just to the right of the power cord or sometimes in the consule area folded up. If you see a spot that looks like old glue to the right of the power cord then the wiring diagram is most likely long gone.
I appreciate all  your help, from all of you. :)
I'm a teacher, by profession, and it's much harder  to teach when the teacher can't see what the student is talking about, in this case, my dryer.   Thanks for staying w/ me until I understood completely.
Woops!  I just "thought" it was fixed.
Still having problems.  I got the heating element, replaced a questionable looking wire and (earlier) installed new thermostat (by heating element) and thermofuse.
Someone told me it could be a thermostat by the blower.  Which one is this?  What does it look like?  Does this sound right to you?
The problem I am having is the dryer glows orange from the heating element (Is this normal?) ...and the dryer does not put the clothes through the "cool down" cycle.  When they are done, they come out very hot.  Outside of dryer is hot too.
Guest
This topic is now closed to further replies.
