slow spin
Started by myk1648, Jun 03 2005 11:17 PM
2 replies to this topic
#1
Posted 03 June 2005 - 11:17 PM
customer has kenmore 27" laundrycenter, made by frigidaire model 417987802791. clothes still wet after spin cycles has been finish. open the front panel, ck drive belt ,ck belt roller tension are ok. ck agitaiton seems ok. could it bad transmission or just the brake package. need help.
#2
Posted 04 June 2005 - 02:15 AM
Look for signs of water leakage at center tub bearing area at top of transmission. If seal has failed and has been leaking just little amounts of water, (hardly enough to notice), that bearing will be going out and causing a slow spin.
William Burk (Willie)
Eureka, CA 95501
Eureka, CA 95501
#3
Posted 04 June 2005 - 10:16 AM
Also, check the drain hose. They have a "duck bill" check valve that might have something caught inside.
Nick
Nick
