Refrigerator Temperature
#1
Posted 04 June 2005 - 09:48 AM
When I received the part, the instructions indicated that it is to be installed in the ice-maker freezer area which did not make sense to me because the freezer area is working fine but the refrigerator is the area not keeping temp.
Questions one: What is causing the temperature fluctuations and what is the recomended why to fix it?
Question two: did I purchase the right part?
Any and all advice is welcome and appreciated.
#2
Posted 04 June 2005 - 10:10 AM
#3
Posted 04 June 2005 - 10:11 AM
Nick
#4
Posted 04 June 2005 - 01:30 PM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#5
Posted 05 June 2005 - 01:07 AM
#6
Posted 05 June 2005 - 02:15 AM
Eureka, CA 95501
#7
Posted 07 June 2005 - 08:14 PM
I have a Jenn Air JCD2389DEQ that had the same problem last October & found out too late it was not under warranty. 209.00 later (55.00 part 61005988 or 5908, 150.00 labor-including using a hair dryer to defrost the freezer coils behind the panel) my refrigerator was again working. Now tonight I find the same problem again. I took apart the freezer back inside panel and lo and behold it is all frosted up again. So I am now using a hair dryer to defrost it to see if that solves the problem. If it does then tomorrow I will go to my local Maytag dealer with invoice in hand and ask for another of these parts.
:X
In addition to this on the inside of the refrigerator door the moldings that are used to hold the door trays in place are warping to the outside and the trays are loose. One has already come out when the door was opened.
:X
Has anyone else encountered these problems and if so have you found any relief from Maytag for what is obviously poor moldings and defrost controllers or whatever they are called?
I had a first generation Maytag refrigerator and had some real problems with it in the door seals geting hot to the touch from what turned out to be a bad compressor, but Maycor fought me for 6 months befre they replaced the refrigerator, first blaming me for not vaccuuming the dog hair underneath on a daily basis:shock:. It took several letters to the Newton HQ and 3 visits from Maycor managers before they agred to replace it. I hope they are more responsive this time or it will be my last Maytag product :poison:
Domo Arigato
Brent
#8
Posted 08 June 2005 - 06:23 AM
#9
Posted 08 June 2005 - 06:52 AM
#10
Posted 09 June 2005 - 06:16 AM
Thanks for replying
#11
Posted 09 June 2005 - 06:57 AM
#12
Posted 09 June 2005 - 06:58 AM
#13
Posted 09 June 2005 - 06:59 AM
#14
Posted 09 June 2005 - 08:11 AM
