Whirlpool washer electronic tempuratire control troubleshooting ?
14 replies to this topic
#1 rkpatt
rkpatt
  • 13 posts
Posted 08 April 2005 - 05:23 AM
The washer is a Whirlpool GSX9885JQO ( the o might be a 0 ) - Catalyst 3 speed electronic washer .
I am having a problem with the electronic water temperature control ( "Accuwash TM " ) .
The automatic temperature control is only delivering hot water in the "warm" setting (Accuwash setting on ) . When placed in the manual temperature mode ( Accuwash setting off ) mode I get get warm water but the water is not warm enough because of the distance to the water hear .
How do I trouble shoot this system ? -thank you
  • 24,698 posts
Posted 08 April 2005 - 12:51 PM
I'm not pulling up anything with that model number.  Re-check it.
#3 The Seven
The Seven
    Sōhei
  • Master Appliantologist
  • 190 posts
Posted 08 April 2005 - 01:09 PM
Do your washer have in-built heater in the washer?
If "No", there may not be any problem in the washer. The cause is the "too low" temp of the "hot water" supply at inlet.
How hot is the water at the "hot water" inlet/tap? Be careful inlet hot water could reach 140 F or higher.
If the inlet hot water is only "lakewarm", there is no way to get "hot" unless there is extra local heating.
The Seven
#4 rkpatt
rkpatt
  • 13 posts
Posted 08 April 2005 - 01:36 PM
oops - The correct model # is GSX 9885JQO ( the letter O might be the number 0 ) - thanks
#5 Ron
Ron
    Kohai
  • 368 posts
Posted 08 April 2005 - 02:26 PM
You can check the accuwash sensor.  Your going to have to get to the control board. Remove the connector marked P5 from the board.  Measure the resistance between P5-5 and P5-4 at the wire harness connector, it should read between 74K and 24K. If it's not in this range make sure there is continuity between the connector and sensor.  If you have continuity here replace the temp sensor.  If the valves and temp sensor check good, you have a control board issue...Ron
  • 24,698 posts
Posted 08 April 2005 - 02:36 PM
I'm sure you're reporting it right, I just can't pull up anything on that model number.  Sounds like Ron has a good handle on the problem, though.
#7 rkpatt
rkpatt
  • 13 posts
Posted 09 April 2005 - 03:10 AM
Thanks Ron . I will check it . BTW where is the actual location of the sensor ? Any links available to diagrams ? - thanks
#8 Mad Mac
Mad Mac
  • 1,432 posts
Posted 09 April 2005 - 05:43 AM
To get diagrams, best place is PartSelect.com. Your model number will come up if you enter GSX9885JQ0 (zero at the end, no space between the X and 9). The sensor is an integral part of the water valve assembly.
Mad Mac....Pray to God he's out there....somewhere.
  • 24,698 posts
Posted 09 April 2005 - 06:07 AM
Sears also the exact same diagrams of your washer.
Here's the direct link to the water valve assembly
#10 AppGuy
AppGuy
    Kohai
  • 350 posts
Posted 11 November 2005 - 12:19 PM
Is there a place to get a good tech sheet on troubleshooting this washer?  I have one that doesn't drain.  It seems that the Drain recirculation selonoid does not seem to be tripping.  Of course the wiring schematic gives Ohms for all selonoids except this one.
#11 Pegi
Pegi
  • 13,120 posts
Posted 11 November 2005 - 12:33 PM
Job Aid manual on this washer....Click Here....
#12 Pegi
Pegi
  • 13,120 posts
Posted 11 November 2005 - 12:38 PM
TECH SHEET         WIRING SHEET
#13 AppGuy
AppGuy
    Kohai
  • 350 posts
Posted 11 November 2005 - 01:00 PM
Good Stuff!  I think I found a new home for those troublesome computerized appliances!  Only bad thing I found is that all info points to EITHER a bad selonoid OR control board.... no way to know but trying a replacement :(  Oh well, I am sure that valve is about 70$  I sure hope it is the problem ......
#14 Mad Mac
Mad Mac
  • 1,432 posts
Posted 11 November 2005 - 05:02 PM
I used to see a lot of this, the solenoid would mechanically jam up. Only answer is to replace the whole thing.
#15 AppGuy
AppGuy
    Kohai
  • 350 posts
Posted 12 November 2005 - 12:12 PM
Well, I went thru every test on the service manual :P all checks out ok.  So hopefully no damage to the board and replacing the selonoid will fix it.  Makes me feel better to see someone say they see it happen alot.  I don't get too many of the newer machines thru the shop, and the other partner would just throw it out.  I'm too stuborn to just throw it away, much less the curiosity gets the best of me :P
