Oven Sensor
#1
Posted 04 June 2005 - 01:36 PM
We have an F4 error on our oven...new house...old appliance...no manuals. We purchased the correct part....replaced it and STILL have the F4 error!! Looked online for 'common mistakes' when replacing this part....have not had any luck. Any suggestions would be welcome!!!
Thanks....JK
(Hopefully I posted correctly!! If not.....I may just have to contribute to the beer fund!!!)
#2
Posted 04 June 2005 - 01:48 PM
CLICK HERE TO BUY PARTS
Appliance Repair In Maryland http://serviceeveryday.com
#3
Posted 04 June 2005 - 01:54 PM
#4
Posted 04 June 2005 - 02:05 PM
http://groups.msn.co...oto&PhotoID=176
At normal room temp your reading should be about 1050-1100 OHMS.
This will tell you if the sensor itself is bad. Or you then know to go and double check wiring or another cause.
Samurai Quote
"Oven sensors sense the temperature in the oven cavity by increasing their internal resistance, measured in ohms, as the oven's temperature increases. This change in ohm resistance tells the ERC the oven cavity temperature and it turns the heating elements or burner on and off, as needed. Now, hang with me, grasshopper, 'cuz we're getting to the good part.
At room temperature, 70°F, the resistance of the most common sensors used today is 1000-1100 ohms. What this means is that if you pull those sensor wires to measure the sensor's resistance and it reads slap-a$$ open, why, it don't take a rocket scientist like myself to figger out that you got yourself a bad sensor! Wasn't that easy?"
#5
Posted 04 June 2005 - 02:19 PM
#6
Posted 04 June 2005 - 02:27 PM
Hang on for a little bit and lets get some one elses advice before you do anything else okay?Thanks- Unfortunately I do not have an OHM tester. Would it be benificial for me to order a new wiring harness or just call a repare man? JK
#7
Posted 04 June 2005 - 02:40 PM
#8
Posted 04 June 2005 - 03:51 PM
[align=left]F4[/align]
[align=left]Shorted oven temperature sensor circuit[/align]
[align=left]Verify the oven temperature sensor wiring harness is OK, if so, replace the oven temperature sensor.[/align]
Sounds like you correctly read the problem, now you need to see if you are actually getting power to this sensor. You will need test interments, or someone who has these. If your harmess is ok, and still get the F4 code, you might want to consider having a professional take a look at this oven..
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#9
Posted 07 June 2005 - 11:03 AM
After telling him what was wrong with it, he said that I needed to order a new computer part for the oven. My thoughts were that the clock is working and all of the parts are registering (w/ the exception of the oven actually turning one)....but the temp comes up....it just won't 'start' when you push start. Anyways.....without him coming to even look at it he wants to order the $135 part!!! He said that once it's ordered there is not turning back, so that disturbs me.
I feel a little naive because #1....oven repair is not my forte #2....It seems to me that one would look at the appliance before ordering that expensive of a part.
Advice????
Thanks....The K of JK....:)
#10
Posted 07 June 2005 - 11:14 AM
#11
Posted 07 June 2005 - 02:16 PM
