Whirlpool Timer
1 reply to this topic
#1 BG
BG
  • 1 posts
Posted 04 September 2006 - 12:15 PM
Hi,
I have a Whirlpool Model LEC7646DQ0.  I was told by my wife that the dryer ran but did not heat.  When I went to work on it, I became aware that it only ran in fluff mode.  It would not run in Auto or timed.
I checked all the thermostats, thermal cutoff, 240 incoming voltage, thermal fuse, door switch, all were good.
I then went to the timer and found only one part not working.  The timer switch 4 which is between the tan and white wires.  It was always open no matter what mode the dial was turned to.  I connected the tan and white directly together, bypassing the switch.  Now the dryer runs on all modes and heats up.  I tested the auto and fluff settings and the timer ran down to zero.  Looking at the wiring diagram, this switch appears to make a connection in either direction.
What does this timer switch do? It opens up at end of cycle and opens intermittently on fabric guard.  Have I created a future problem by bypassing the switch?  Is there any reason that I should not tie the tan and white wires together?
BG
#2 Mad Mac
Mad Mac
  • 1,444 posts
Posted 04 September 2006 - 02:06 PM
[align=left]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot.jpgfile:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-1.jpgfile:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-2.jpgfile:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-3.jpgfile:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-4.jpgfile:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-5.jpgA check of your wiring diagram shows that the only issue will be the dryer not stopping. See:
http://www.servicema...t - 3401723.pdf
file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-6.jpgPosted Image
[/align]
Mad Mac....Pray to God he's out there....somewhere.
