Kemore model # 88752793
5 replies to this topic
#1 faust
faust
  • 14 posts
Posted 04 September 2006 - 02:17 PM
There are 3 wires that the new power cord i'm hooking up goes to the top one is black the middle one is white and the bottom one is red which is the ground on a kenmore washer dryer combo? The model number is 88752793.
#2 Pegi
Pegi
  • 13,120 posts
Posted 04 September 2006 - 02:23 PM
You will have a seperate green ground wire that attaches to the middle post with the white wire and attaches to the case on the other end..on a normal 240 volt hook up, assuming this is a 240 volt unit?   What is before that model number, 417.?  110.? Would depend on who made this for Sears what that prefix would be, suspect 417=Frigidaire if this is a stack unit....
#3 Pegi
Pegi
  • 13,120 posts
Posted 04 September 2006 - 02:29 PM
Nope, is a Whirlpool stack unit..this is good..WASHER/DRYER LAUNDRY SYSTEM - 110.88752793
#4 faust
faust
  • 14 posts
Posted 04 September 2006 - 02:30 PM
Thanks for such a quick responce. The old cord had 4 pronges and i did see the green wire with the white one. The new cord is three pronged and all the wires are grey. I was told by the sales person that the middle wire was the ground. I need to know which wire of the wires in the machine to hook the ground to.
#5 faust
faust
  • 14 posts
Posted 04 September 2006 - 02:33 PM
the prefix is 110.
#6 Pegi
Pegi
  • 13,120 posts
The 4 prong cord had a seperate ground wire, the green one,... with the 3 prong cord you will need to make a ground wire and attach it to the middle white wire/post on the terminal block and the other end to the case where the green wire of the 4 prong cord attached...
