angelgirl1005829
Frigidaire Dryer Problems
4 posts in this topic
hi i have a frigidaire dryer : model number : FDE436RES1.  It has been working alright but it was sqealing very loudly while drying.  a couple days ago it stopped working.  the drum will not turn but the heat still works.  i had a friend check to see if the belt had snapped, but it's still together and fine.  my friend said that the pin in back of the drum broke.  My question is: Can i fix this on my own without getting hurt or do i need to call a repair man?  Any help you can give will be great.  thank you.
check your model number again i can't get it to run on any site
Yes you  can do it !
Frigidare has a complete berring  kit including grease.
I would also replace the front upper drum berring if it is worn or rusted.
Inspect the 3 plastic slides on the felt.  (if on this unit)
Wear cavlar gloves. (edges are very sharp !)
You need to remove the whole front of the dryer to remove the drum.
You may need a Canadian screwdriver. (Square #2... not philips)
