schultzmom
dryer- no drying
8 posts in this topic
:yikes:    Help! Mother of 2 boys and my dryer suddenly won't run anymore. It was working great last night, but this morning....nothing! The heating element is working can, I feel the warmth on the clothes. Can I fix this? Or.....Do I have to buy a new dryer?!?!?!?
gas dryer,element??   what kind/model of dryer is it- sounds like a belt broken,but not knowing exactly what it is ,can't be certain.  crystal ball is fogged up today
It is a Whirlpool gas dryer.....probably about 8-9 years old. Does that help any?
Open the dryer door and get us the model number.  When it "does not come on" is the dryer humming like the motor is running or is the dryer dead like it is unplugged.
model # is lg5781xkn1.....it sounds like it is running....
i think it is the belt, because i can turn the drum realy easily by hand. i wasn't able to do that before. does that sound right?
If you can hear the motor humming and the dryer is heating sounds like is a simple broken belt problem.  Be sure to replace the drum rollers and belt idler assy. while you are in there.
thanks....i appreciate the info. i will let you know how it goes.
grasshopper%202.gifIf you're having problems with a gas dryer that only heats a short time then shuts off the flame, the first thing to do is to completely disconnect the vent from the dryer and run it again to see if the symptom changes. If it does, you know the problem is the vent, read this page for more info.
If the problem doesn't change with the vent off or the burner never fires up at all, then the problem is inside the dryer. This page will help you troubleshoot the key components inside the dryer.
A common problem is the glow ignitor gets hot and turns orange, you hear a click, but no flame and then the ignitor goes out. This is almost always the gas valve coils, an inexpensive part that's easy to change. Don't mess around with just changing one of them, save yourself a headache and change out the set. You won't be out a lot of shekels. Buy the set here.
If the dryer runs for a while, shuts off and then won't even let you restart it for a while, this is usually a bad motor--the motor is overheating and its internal thermal overload is kicking it off. You should confirm this by measuring for 120v at the motor's run start winding terminals.
If you need help making electrical measurements and using a multimeter (or if you don't know what that is), read this page. You won't fix much in the appliance world without a multimeter. You can buy a good quality, inexpensive meter here.
[align=center]cover02.gif[/align]
