Maytag Dryer DG7500 Won't stop Drying
3 replies to this topic
#1 kwseibert
kwseibert
  • 2 posts
Posted 08 April 2005 - 06:54 PM
I have a Maytag Dryer DG7500 that keeps running  even when the clothes are dry. I think it may be the Moisture Sensor but I cannot find it.  I took the dryer apart looking but to no avail.. :(
Thx for your help
  • 24,721 posts
Posted 09 April 2005 - 04:15 AM
Read this thread, same problem as yours.
#3 kwseibert
kwseibert
  • 2 posts
Posted 09 April 2005 - 07:17 AM
Forgiviness please.. :(
The timer in the air fluff cycle continues to rotate.  It is only in the Automatic cycle that  it never moves. I can manually turn it to off and it works fine. I looked for a moisture sensor but I cannot find one.   The vent is completely clear
  • 24,721 posts
Posted 09 April 2005 - 09:21 AM
Forgiveness for what?  None required.
Ok, with that additional piece of information you supplied, that points to a bad cycling thermostat.  There are several different types, not sure which your is.  But enter your brand and model number in the table at the bottom of this page.  You can pick the cycling thermostat you need based on the one you have installed-- they'll show you pictures of the various types.
